Hi guys, the standard R34GTT intercooler is a bit bigger (thicker) than the R33/32 one. It's still not in a good location, but the R34 ducting is better.
It really depends on how often and for how long you are going to run it at full boost. If it's road only car or a road/drag car I would reckon 200 rwkw may be OK. On a circuit car it would not have enough airflow or mass to control the temperature over any sustained period, 2 or 3 laps and it would overheat the inlet air.
Hope that helps
Does anyone know if that (R34 cooler) is a straight swap with the stock R33 side mount ?
I was considering this as a low-cost DIY alternatives to FMICs...
Would also be nice to hear if anyone else has already tried it and what they've noticed different...or any other opinions...
yep, straight swap. a few guys in the HK skyline club have done this to their 33 GTST's.
so from a stock setup, what do they do besides changing to the R34 cooler ?
add some boost ?
A friend was considering that cooler, a cheap $100 turbosmart boost controller (or bleed valve - if those terms are interchangeable?)
and leaving the rest with a possible EMS upgrade to tune those mods together.
add some boost ?
refer to what SydneyKid said...what application is the car going to be built up for?
Street terror?
Circuit basher?
Straightline warrior?
I don't think I've ever brought up any hi amounts of boost in traffic...especially with the peak traffics lasting longer and longer lately...
on that note it sounds like the stock one will do fine...and for that bit more without the huge overheads of mods, the R34 cooler as a simple upgrade...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
