hey bro i will give you good advice ......DONT GET IT ! it may be good after a while but it traps heat and moistier belive it or not and in about 6 months u will have no exhaust left too heat wrap ...seen it alot of the time when i pull cars apart with the heat wrap ....may be good but it kills your exhaust ........
i would get a special paint an insulant paint not sure what its called but it does help .....or even better theres special sh*t u can put on your undercarrige like the heat wrap but works heaps better many ppl wit rotary's yous it .....
...trust me man i did it too my mates car when i started out in the trade of performance and shit 6 months later i pulled the wrap of cause he herd leaking under it and sh*t me there was just a skeliton of the exhaust ..... man we were stunned ..so we tried too claim but they say its only for drag use or some shit .....
sh*t. I put it on already.....
should'v read this post firs.t......
but would it help if I spray the exhaust first then wrap it and then spray on the wrapped exhaust again?
the guy told me at the exhaust place to damp the wrap with bit of water and then wrap.
and this wrap is pretty expensive !!! cost me 80 bux for the wrap and the spray
The stuff from Autobarn and places like that are a cheaper alternative to REAL exhaust tape.
If you want the good stuff, then I'd suggest to visit your local Revolution Racegear supplier, they have the stuff that goes on drag, rally, sprint cars. It's a little dearer, but if you want it, then you'll pay for it.
yeh i reckon dont use the wrap in the first place .... it was a real expensive blunder for me ..... i am now using the paint n under carrage matt .... works much better ......
now come too think of it by spraying it then applying the wrap u could get pass the corosion but under the wrap it gets bloody hot and the paint will most likly peel off then just start that shitty prosses again .....
guys, i went with jet hot coatings to get my dump pipe coated in some sort of ceramic coating inside and out, handles up to about 1000 deg, and they say it retains the heat in the pipe and out the exhaust...cost about $80 plus postage, and you get a free recoat if the product does happen to fail, there number is 1800700468
  • 2 months later...
sorry to dig up the old thread but... what is "the good stuff"? is DEI good stuff? and with the good stuff is corrosion still a problem?
thanks
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
