hi
well after looking over my mates N1 1993 BNR32 ive noticed he has the exact bilsteins exhaust turbos. all he has that are nismo that i dont have is his seats. i have normal seats. but i also have a Nismo 260kph cluster. i was told that all my items are factory. so leads me to wonder if mine is an N1?
Nismo front bar (resprayed and nismo sticker came off)
Nismo exhaust
N1 turbos
Nismo stickers throughtout cabin
Nismo 260 Cluster
N1 Bilstein suspension
thats all i can think of.
let me knw as i would love to knw.
here is the read out provided by karen
thanks :P
Hi guys,
I am after a VIN for a GENUINE R32 GTR N1.
Can you ask your mate if I can have it?
I need to order an N1 bar from Nissan, but they reckon I need a VIN from an N1, bcoz they can't find the part number!
Cheers!
:P
How can you tell?
Psychic powers?
Because the KBNR32RXFSLM2G build identifier is the same as for the early R32 Gt_R's The N1 editions had completely different sequences.
There is NO DIFFERENCE between an N1 bar & that for a Nismo version. Apart from the slots & the intercooler mesh there is no difference between the N1 version & the ordinary GT-R. So why do you want/need an N1 version (not that there is such a thing?)
Psychic powers?
Actually, you are right, I want a NISMO front bar. But I can't find a part number or a suitable VIN to give to Nissan so they can order it. They reckon they are having trouble finding a part number themselves, gave me some crap about just getting a stock bar and buying vents seperate, which i think is silly. I prefer a factory one.....
So any help would be appreciated!
Cheers!
haha.
hmm ok thanks guys.. shoot my hopes down lol.
it just seemed weird having the same N1 stuff as my mates N1. apart from he has red stitching GTR seats, red stitching wheel and shifter. and thats it.
well thanks guys :thumbsup:
how do u check what items are optioned from factory?
cause i was told that everything on my GTR was from factory.. :) (better not be just salesperson talk)
When you get the number let me know, im after one of these nismo bars too.
Cheers
u talking about the vents..? thats for V-spec and only an option. the N1 GTR my mate has no intercooler vents.
also mate ur avatar is top stuff i love the way it doesnt crumble it just bounces off the wall..
and look at it understeer. :thumbsup:
Cheers!
:thumbsup:
I am clearly missing something here. I gave you the build number of a NISMO edition R32 GT-R in the other thread. They were the evolution model that the group A cars was officially based on. They had all the extra bits of spoilers/cut outs etc. If there is any difference between the part numbers for the front spoiler on that & the povvo pack GT-R it will show up. My thing has the slots in the front bumper. They are nothing special - you just need to trim the bumper to suit. Other than the holes the bumper is exactly the same. They aren't at all hard to put in as there is nothing behind the bumper on that location.
If you want NISMO bling there are tonnes of other bits & pieces they make. Most of it is hideously expensive.
In all honesty the Nismo add ons are nothing special in terms of quality. The extra spolier bits warp, distort & bend & generally look pretty awful after a few years. I have bought an after market replica of the rear lip spoiler on the back of how bloody terrible my Nismo item looks. Carbon fibre generally looks prettier than plastic in any case. :)
As far as I know the only option you could get on your standard R32 GT-R were heated external mirrors....
Edited by djr81
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
