  • Replies 66
for humour
ecu $1500 tuned
turbos $3000 fitted
tyres $1000
clutch $1200
strip interior $1000
no exhaust $1000
fuel upgrade $1000
cold air / intake setup $500
nos kit $600
4wd upgrade $800
afm upgrade $800
4wd controller $350
it will fail on stock internals
ECU, big turbo/s, NOS kit, clutch and some injectors less than 5k = stolen hardware or not possible
the ecu alone is $1000 untuned
big turbos $3000 a pair
nos kit is $600 ish
clutch is $1200
Turbos 2860-5 - $2500
ECU - $1000
Injectors - $700
AFM - $600
Fuel pump - $200
Exhaust - $700
Clutch - $1200
6900. Thats not including anything else you'll need to replace along the way.
Or the tyres you need to race on
For 5k, i say it cant be done. Even if you used 2nd hand parts. Its still out of reach
You dont need NOS to run a 10.99
nos kit is $600 ish
clutch is $1200
hmm, maybe if you buy all ur products brand new....
you can get a good set of second hand HKS GT2530 for under 2k (dont know if they will be big enough), that price inc of shipping and buyers fee (buying from yahoo auctions)....
but having said that, i personal don't think it can be done even with second hand parts...
Twin Turbos $2000-$2500 (or $3000-$3500 for second hand hks t51r or similar turbo kit)
then you have ecu (min $900 for pfc + $300 to $500 for tuning = 1.5k)
maybe smash in a FPR turn up the pressure as much as you can and hope the stock clutch holds up LOL!
yes ok, i forgot about the fuel.
but assuming you scored the gear cheap secondhand, chinese turbos no intake filtration etc, dodgy hack togeather plumbing, decent wet nos can had for under $400 second hand yeah? surely a clutch to hold it could be had for 1k ay? and all this only has to hold togeather for a short time... how many kw is needed to get in to 10`s?
maybe smash in a FPR turn up the pressure as much as you can and hold the stock clutch holds up LOL!
a pair of 2530s with
stock fuel rail
stock injectors
stock pump
stock clutch
wont even pass tuning, it will lean out off the planet and go boom
stock fuel rail
stock injectors
stock pump
stock clutch
rofl he never said it was ment to last :)
ps i know its not possible im just throwing wild ideas up in the air LOL! how much pressure can the stock fuel line hold?
sure it would be fun to try but it wont happen
and an xr6t i dont think could get into 10s under 5k
they apss kits to get 10sec are like 20k
im pretty sure i saw a stock turbo'd xr6t do a 10second pass (article on autospeed i think). 20K is over the top, if you put it together yourself you could do it under 10K easy.
why has everyone gone for twins on a 'cheap' drag setup ?
go for a big single (garrett off the shelf). injectors, map sensor PFC, clutch, exhaust and ALOT of nos. i rekon you MIGHT just scrape in under 5K, with some second hand parts :)
exactly, and forget the xr6t, the cars that go into the 10`s have alot of money spent... but still on the stock gt3540 with ported wastegate mind you...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
