96 GTR Vspec in need of some mods
I want a very reliable car and I am not chasing high HP. Car is a everyday driver and does get used on the race track occasionally. I want good low and mid range response without running out of breath in the upper range. I also don't want to lose all fuel economy when not being used.
Current Mods all done by CRD by previous owner (excluding clutch)
Turbo back exhaust
Cam Gears
K&N air filter
Iridium sparkplugs
Spitfire coils
Race clutch
Unsure of 2530 or GT-SS Turbo's/ HKS or Garret?? or others
Reliability mods of high importance EG oil cooler etc
Power FC or others?
Total price must leave enough money for the installation at a good place. Please include reasons for add-ons
Gee slow response, how about comments on my first thoughs
HKS 2530 turbo's (power and reliability over originals)
Standard Power FC (better power delivery, fuel usage)
New fuel pump (probably the first thing to need changing at 300awkw)
Sump baffle (circuit type to assist oil management in corners)
Extra oil return line from the head (to assist oil in the head problem when at constant high revs)
electrostat fan (fan needs replacing anyway so releive the load on the engine)
Boost controller of some sort (no good managing engine if you can't manage the boost)
External OIl cooler (keep that oil temp at manageable levels)
Remote oil filer (just for the ease of maintenance)
keep as is
Suspension
Air filter system
gear box, clutch
no head work
Comments on this please
Edited by a20089
If you want reliable, this is where to go.
GT-SS - turbos hands down winner for response.
PowerFC - cheap/easy/lots of good tuners (CRD included)
Injectors - Nismo 555/550's
AFMs - Nismo AFM's. Bolt in replacement
Fuel pump - whatever pump you can get, costs around the $220 mark.
Oil cooler - might aswell, its not that expensive :closedeyes:
Good boost controller
Thats around approx 7000-7500 give or take. Depending on prices at the time and labour costs.
Dont worry about sump baffles, extra oil returns from the head etc. Its motor out job.
And... For a car thats only going to see the occasional track day. Absolutely no need. Just run an extra 1ltr of oil in the car for the track day.
Then you wont have a problem. Every GTR here i melb i know that does it (lots) never have issues and they are attending 8-10 track days a year with more power than the GT-SS will ever make :)
keep as is
Suspension
Air filter system
gear box, clutch
no head work
I have a R33 GTR V-Spec which I purchased primarily stock about 4 months ago. Mine isn't a daily driver but I do expect to get it to the track and I'm looking for a very solid car before, at some time in the future, rebuilding the motor for big HP. A few of my thoughts.
You can spend a bit on suspension and brakes and get a good return. I have put on new brakes (Project Mu rotors, Nismo Pads, MCS, & braided lines and gotten a good braking improvement (around $2000).
I'm also dropping money into suspension. Take a look a the SK group buy. I'm actually only buying the stabalizer bars and camber/caster parts (around $1000 plus install). I think this will give the biggest bang for the buck as a GTR suspension isn't bad to begin with and this simply tightens it up, allows better alignment/tuning and improves handling. Even the cheapest coilovers will cost $1300 and it is doubtful you will get the same performance improvement, though if you want to lower your car this will allow that where what I have done won't.
I've added an Apexi intake ($400). Easy upgrade - and to be childish - I love in the intake sound.
Next is an external oil cooler with filter relo. Bot one from JJR for $400 but the cost will be in installing it. I understand the idea of running a sump baffle and why it is better but I'm not pulling the motor just for that, which is what you need to do. I've also put on a Nismo oil seperator ($400)
So I'm spending probably $4000-4500 including labor and have what I think is a very solid base car which stops and handles very well and should support track days w/o blowing up.
There are people here who can comment better on engine upgrades than I can.
If its a stock bottom end, i would go with smaller turbos like GT-SS and aim for about 300rwkw, probably just under... anymore and you're going to lose the 'reliability' part you want. Stock fuel pump doesn't need changing unless it's stuffed, good for about 600HP@fly.
GT-SS
PowerFC + good tune(this is the key)
Oil Cooler
THen i'd spend money on suspension setup/geometry. GTR's stock handle pretty average, and that goes down hill if you throw more power without touching handling.
Some good ideas please keep them comming. I am not against doing work on the engine as long as it fits within the budget, I haven't suggested RB30 conversion or the like as I would assume it would be out of my price range. Someone suggested a cam replacement for better response and possibly still within budget?
As for GTSS turbo's, Garrett seem cheap in comparison to HKS, are the HKS's that much better? $2500 v $3300 for the pair. I've alos been told the HKS fit as a direct replacement much better than Garrett.
Suspension work will have to wait at this stage, the biggest upgrade I'd do there first is better tyres. I don't want anything stiffer as an around town car, and as high as it is, I can barely make it into work's garage so not interest in lowering it.
Edited by a20089
i just got my car back from CRD and i'm so happy with the mods i got the following
2860-5 turbos
trust cams 260' deg
720cc injectors
trust fuel rail
sard reg
z32 afm
i had a good intercooler +powerFC+exhaust+bosst controller
it made 340klw at all 4 and it makes 16psi at 4000rpm it was tuned for more response than peak hp,the mid range power is awesome heaps of torque,the engine is 100% stock if i had a built bottom end we could push the power a lot higher really looked into all the turbo choice's and was undecided for ages but i know i made the right decision this is a really great package
Suspension work will have to wait at this stage, the biggest upgrade I'd do there first is better tyres. I don't want anything stiffer as an around town car, and as high as it is I can barely make it into work's garage so not interest in lower it.
Tires are the best handling bang for the buck but I kinda consider them maintainence. Note that what I have done does not replace the springs (no stiffer than a stock GTR) and does not lower the car.
HKS come as a kit with everything, Garrett don't, but either are fine, Garret Make the HKS anyway.
Suspension - if you don't want to change shocks/springs you can still do geometry and swaybars.... will make a big difference, but without suspension work, 300rwkw will be a handful around the track.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
