I have been debating for a long time now which exhaust to get, and i think ive finally come to a decision. I think im going to go with a Blitz NUR Spec, i have heard good things about these exhausts, they have good sound, they are a full stainless system, and give good performance upgrade.
Ask EGA41T he has a NUR SPEC on his S2
all this talk of jap brand exhausts needing mufflers, etc. being cut out makes me wonder why people still buy them?
i'll stick to kermit spec exhausts. :)
Unfortunately, not all of us have that option though. I asked kermit about an exhaust and got a quote roughly the same as a bolt on system, and that didn't include the cost of the resonator and canon that I would have to supply myself.
I personally lean towards the NUR spec myself.
Just make sure you end it in a big ski ramp jap style! :)
I have an R32GTR Nismo exhaust on my Stagea. It was quiet, but effective on the GTR (300 rwkw) and seems equally so on the Stagea. Makes no more noise than standard at up to 3,000 rpm, so great from highway running perspective, zero resonance. Over 3,000 rpm it allows the normal RB type howl, audible but never annoying.
The guys at Liverpool Exhaust and I modified it to fit the Stagea, added around 100 mm before the rear subframe and around 80 mm after the rear muffler (ie; extended the tail pipe).
:nyaanyaa: cheers :domokun:
Well I did a bit of research on the Blitz NUR Spec R... and it was looking real good until I looked closely at the photos of the Cannon.... and the tip is angled!!! Call me fussy but personally I cant stand angled tips :P
Right now the HKS looks the goods... :banana:
Does anyone know whether something like this would require much modification to fit a stagea?
http://cgi.ebay.com.au/NISSAN-SKYLINE-R33-...1QQcmdZViewItem
I know its a cheap chinese brand or whatever it is.... but i just want something very cheap that does the job. :)
as sydneykid said, they need to be lengthened a tad, but the rest of it fits fine.
im 99% sure even just adding a bit in between the cat and the cat back will be suffice, but how sydneykid did it is probably a more snug fit.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
