Hi Guys,
A mate has just recently purchased a cooler, and im hunting an installation guide other than the one in the DIY/Tutorials section as its a different piping setup. Had a quick google and forum search and didnt come up with much, can anyone point me in a direction?
Regards in advance,
Nash
https://www.sau.com.au/forums/topic/164466-r33-cooler-install-guide/
That setup has about 4 different guides in the DIY section.
Maybe not complete step by step guides but pics and hints given general good info of where everything goes.
Don't be scared to cut the reo bar and the front plastic bar.
And you WILL need to cut a hole thru the engine bay wall to feed the piping thru.
Just make sure you've lined it up 10 times before cutting....
Good luck
I've done it once.
..and did it in various stages.
Figuring out the front bar was hard enough so i did that on 1 day. (removing it)
Vaguely figured out the postioning ofthe FMIC another day.
Put it all back and drove around for a few weeks.
Came back to it another weekend and went for it.
Started Sat and finished Sun
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
