so i went down to advan and asked for a quote to do an rb30det for me they said 5450 dollars and thats if i provide pistons, the block, all gaskets, oil pump, rod bolts they also said that they'd have to do some work on the head which they will provide all the parts for.
is this expensive? or not? is there somewhere with the same quality of work only say a grand cheaper lol 5450 is a bit over board if i can save a grand and put that towards a new turbo or something would be nice.
Any advice, contacts or workshops given will be greatly appreciated!
ta
Shane
https://www.sau.com.au/forums/topic/164474-where-in-sydney/
5.5k sounds about right.
Take off a grand for enine in/out and 4.5k sounds pretty much spot on the money. Maybe a little high. But not really anything i would question.
Rod bolts/oil pump isnt that expensive, and im sure if you asked them to source pistons they would.
Good work costs money.
I've learnt the hard way many times, you try and cut $500 here, $500 there with people who might have some expirience, but its far better to pay people that know the most.
https://www.sau.com.au/forums/topic/164474-where-in-sydney/#findComment-3049974
whats enine? hmm yeah your right, just sometimes they are very expensive to deal with and almost always the quote is about a grand less than what it ends up lol
https://www.sau.com.au/forums/topic/164474-where-in-sydney/#findComment-3050024
ok heres the list of parts im going to need if i missed anything ppl please do advise me cheers. Im also going to need advice on the following
1. pistons (what size should i use? what sort of compression do need, i want response comparable to a mines gtr ;) if thats not asking too much lol)
2. rods? or just rod bolts?
3. block (obviously)
4. engine gasket kit
5. Metal head gasket (again i dont want very low compression coz i want good torque figures too)
6. the head will be taken care of by advan (what sort of work would they do?)
7. anything i missed?
https://www.sau.com.au/forums/topic/164474-where-in-sydney/#findComment-3051620
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
