Hey all,
The other week dad put a new battery in my car. Since then, alot of problems have come up. It's an R32 GTS with an RB20DE btw.
If the car goes over 100km/h, it does that beeping. Now I'm not sure if that is meant to happen or not, but i know on alot of drift movies and stuff I've seen it happens to them too. Just wondering if it just requires the ECU to be tweaked to allow it to go over?
Also, my major problem......
When we first got the car it was fine. But ever since the new battery, when first start my car up and go for a drive it chugs for a while. Almost like kanagaroo hopping. After a while it goes away, probably because the engine is now warmed up. What i don't get though is that it never used to do this. It has only done it since the new battery has gone on :D
Any help would be appreciated asap, as i get my P's tomorrow lol.
https://www.sau.com.au/forums/topic/164492-chugging/
Hey all,
When we first got the car it was fine. But ever since the new battery, when first start my car up and go for a drive it chugs for a while. Almost like kanagaroo hopping. After a while it goes away, probably because the engine is now warmed up. What i don't get though is that it never used to do this. It has only done it since the new battery has gone on :P
oh... dear... god...
either way, it doesnt sound like a battery problem at all... the only real problem with batteries are
FLAT: it wouldn't start if it was
BAD CONNECTION: might be it, check your connections, but i doubt it
SURGE: your new battery might have let out a bit too much power at one point and fried some shit...
all highly doubtful...
your ECU, unless f**ked, doesnt need anything... try a different battery and see if that fixes it... probably your best route of attack...
when i was your age, i had a 1978 honda prelude... had been on this earth twice as long as me...
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3058322
Thanx for the help DRD.
The chugging has now seemed to stop, but.......
Instead of chugging, every now and then the engine loses power. Like I'll be driving along then it was basically just stop revving and role along, then eventually it'll kick back in. It's strange......
Any help on this aswell? lol
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3059419
i would say its time to start taking care of that car...
it needs a service... sounds like your coilpacks might be rooted... but it also sounds like you picked this car up for cheap...
take it to someone who knows about them and get them to have a look at it... its gunna cost you money no matter what you do, but this is probably the best thing to do...
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3059923
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
