Hey all,
The other week dad put a new battery in my car. Since then, alot of problems have come up. It's an R32 GTS with an RB20DE btw.
If the car goes over 100km/h, it does that beeping. Now I'm not sure if that is meant to happen or not, but i know on alot of drift movies and stuff I've seen it happens to them too. Just wondering if it just requires the ECU to be tweaked to allow it to go over?
Also, my major problem......
When we first got the car it was fine. But ever since the new battery, when first start my car up and go for a drive it chugs for a while. Almost like kanagaroo hopping. After a while it goes away, probably because the engine is now warmed up. What i don't get though is that it never used to do this. It has only done it since the new battery has gone on :D
Any help would be appreciated asap, as i get my P's tomorrow lol.
https://www.sau.com.au/forums/topic/164492-chugging/
Hey all,
When we first got the car it was fine. But ever since the new battery, when first start my car up and go for a drive it chugs for a while. Almost like kanagaroo hopping. After a while it goes away, probably because the engine is now warmed up. What i don't get though is that it never used to do this. It has only done it since the new battery has gone on :P
oh... dear... god...
either way, it doesnt sound like a battery problem at all... the only real problem with batteries are
FLAT: it wouldn't start if it was
BAD CONNECTION: might be it, check your connections, but i doubt it
SURGE: your new battery might have let out a bit too much power at one point and fried some shit...
all highly doubtful...
your ECU, unless f**ked, doesnt need anything... try a different battery and see if that fixes it... probably your best route of attack...
when i was your age, i had a 1978 honda prelude... had been on this earth twice as long as me...
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3058322
Thanx for the help DRD.
The chugging has now seemed to stop, but.......
Instead of chugging, every now and then the engine loses power. Like I'll be driving along then it was basically just stop revving and role along, then eventually it'll kick back in. It's strange......
Any help on this aswell? lol
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3059419
i would say its time to start taking care of that car...
it needs a service... sounds like your coilpacks might be rooted... but it also sounds like you picked this car up for cheap...
take it to someone who knows about them and get them to have a look at it... its gunna cost you money no matter what you do, but this is probably the best thing to do...
https://www.sau.com.au/forums/topic/164492-chugging/#findComment-3059923
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
