hi
i was reading about shimming R33 GTS diff...a few pages back
then i notice it wasen't worth it at all cuz it will only last weeks/month
and since i am putting out about 600hp anyways
but on a BNR32 will it be actually do-able? because it being a 2way from stock. rather then open diff like R33 GTS
if i shim it, it will just be a stronger two way ???
so will it be worth it shimming a bnr32 diff ?
have anyone have experience
if not...i am looking for a Crazy locking lsd for a 600hpish BNR32 !! which brand/model do you guys reccommend ?
thx
https://www.sau.com.au/forums/topic/164512-shimming-bnr32-rear-diff/
I think they are 1.5 way stock rather than 2 way. Also I have spoken to people who have done this and it was very much worth their while. They also replace the clutch packs in them I think.
I have just put an R32 GTR diff in my car and am waiting for a track day to test it's condition. If it's a bit tired I will be doing this for sure.
i'm not sure i completely understand the question. but we are talking about a kit which has replacement clutch disks (and apparently more of them) for a standard GTR diff. so yeah it fits in the stock housing? it's still the stock diff... just with newer, more clutch packs in it.
I run a gtr diff with nismo 5bolt axles. I was told they are setup pretty loose from factory and can be shimmed a little providing its plates are good.
Mine is fairly tight but doesn't clunk.
Awaits the nismo clutch pack. Any news on its cost?
shimming a diff is not a good solution - clutch plates are made of friction material and will give you LSD action, shims just make everything want to bind because there is less clearance than designed.
no mate, loosly used term. it actually relaces the thick side washers inside it with 4 extra plates so yuo get a stronger lsd. they stip out quite easy standard as theres only one plate engaged on the axle shaft.
i had mine done a stewart wilkens rally. in mulgrave.
if shimming is no good
then which LSD do you recommend?
something crazy, for track and drift
as above. :)
