R34 GTR Vs Evo 9
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 49
get the GTR, As good as Evos are, its just a shitty lancer :D
Ditto. If all you want is a wheelbarrow that handles go buyt a kart. Both the evo and the rex are darn plain shitty looking cars compared to a 15 yo line. As for breakage. if you leave the line at the same power output as the evo it wont break either.
Trouble is, we keep on trying to squeeze more and more out of them. That said. who gives a shit, If it aint breaking you aint tryin hard enough. Leave them alone and they wont break, Mod them and they will. So will the others if they are taken to some of the extremes that lines are taken to.
As the driver of the giant car said. he owns both and with the same dollar invesatment in the evo it still wont blow wind up the arse of their gtr. So much for their performance kudos.
An EVO holds the record at Tsukuba.....by a decent amount too, but that said for every fast EVO there is a GTR that is close and visa versa at TS in recent years
I think Dollar for dollar they would be close enough for the driver to be the main difference!
I hear what you are saying Andy but imo the only thing that even puts the evo near the gtr is the fact that it is a a lightweight.
An Evo is as heavy as an R32GTR!
And Light is good :whistling:
But each to their own
Really tho. He sold the gtr for a reason to buy the evo. He needs to ask himself what that reason was. If it was 4 doors and a boot, then the gtr is a stupid option. If it was he just didnt like the gtr as much as the evo, same deal, buying a newer one wont change that.
Grrr this is sooo hard and confusing, its true what u guys have said bout modin skylines up n pushin em to extreme and breakin em, same applies to evo's. id own a evo over a crappy rexy any day and any time ;)..... U R A BUS Hahaha
any ways yeah im hell keen on the 34 gtr and i love all skylines, im just 50 50 which sux. well i'll put my evo up for sale and see how that goes and hopefully i mite be back with the liner cruise YAY :whistling:
I'd say stick with the evo.. but then again i know how much u love ur bloody gtr's :P haha just gotta keep in mind also that i KNOW u'll end up doing quite abit of mods if you decide to get the GTR (even though u say u wont :P hahaha).. the evo is has warranty for ages, power is fantastic.. it goes so beautifully around corners, low k's, almost brand new.. and im sure the re-sale value will hold alot more than the GTR, and best of all its sexy :):wub::thumbsup: hahahaha
but all in all, its ur money pumpkin and im sure u'll make the right decision :):santa:
squish this is for u! >_<:yes::(
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
