Hey guys, im getting my car fixed after the last drag day when my clutch let go (or whatever it was that let go) and im going to go out and buy all the mods now so i can do it all at the same time. Basically im only posting this because im not sure on the "detailed" information that is needed for mods such as "what cc injectors" or "which cams to get". Ive got a 5k budget including tune + labour.
So what im after:
- i want to have not much more then 300rwkw
- want to hit a high 11sec 1/4 mile, car has run a 12.3sec as is
- keep in mind it will be a daily driver as well
- i want turbo lag to be minimal with a good strong mid range punch
What i currently have already (that would make a difference). currently running 250rwkw (dyno sheet is in the RB26 turbo upgrades sticky):
- mines ecu
- full turbo back exhaust
- slide hi flow rb26 turbos
- k&n panel filter
- os giken twin plate clutch & flywheel
- hks evc 3 boost controller @ 15psi
- splitfire coilpacks
- JJR hardpipe cooler kit
Im pretty happy with the brakes & suspension setup i currently have, got a few upgrades to make here and there but this is excluded from the budget.
This is what i have planned so far:
- power fc - ~$1500 inc tune
- injectors (what cc/brand?) - ~$1000 installed
- fuel pump (looking at a bosch 040) - ~$400 installed
- cams & cam gears (type/brand?) $?
anything else ive missed? i dont think i will need to upgrade the air flow meters for the power im after (under 320rwkw) and i dont really want to open up the engine other then the cams, unless something is really needed.
Thanks guys.
https://www.sau.com.au/forums/topic/164549-what-can-i-do-with-~5k/
  • Replies 45
5k? Thats more than you need :closedeyes:
PowerFC - $1500
Injectors - Nismo 550/555 - PT# 16600-RRR60 - $750-$800, then whatever for installation
Fuel Pump - $320 installed i wouldnt pay anymore than that for a Bosch pump install, its a 20min job and the pump costs $220
Adj Cam Gear - $200 installed
Tot - basically 3k
You might have a 100 here or an extra 100 there. But 3k will get ya over the line without a drama.
Nismoid I think your a little under with the Cam gears quote. 2 gears and instal at $200???
AFM's are not needed for what his chasing. I would not be worried about cams either and like others suggested use the money on a decent set of tires if you havent already got them.
Seen good and bad tunes coming out of bel as of late, dunno what the go there is. I fixed up a tune on a 180sx today that was done there, Owner was most disapointed in the results.
Edited by Risking
I did say give or take a 100 here or there (just add 100 on if thats the case)
Cant be spot on everything all the time :P
Modified stock ones IIRC are $150 i can get them for.
Not sure if thats RRP or whatever though, i dont stay on the prices all the time ;)
PowerFC - $1500
So you wouldn't bother with replacing the fuel rail? air filter? or even replace stock flywheel & clutch?
PowerFC? I've never heard of it (Being new here and all), so I'm guessing that is an aftermarket ECU right?
Mark. If take the time to read the first post, you'll see the parts that hanyou already had on his car.
These include a better clutch, panel filter upgrade among other parts.
These were left off the list because he does not require them.
If you have never heard of a PowerFC, i suggest you spend a lot more time reading. Its the most common choice of ECU on a Skyline :nyaanyaa:
And you certainly dont need to change the fuel rail for 300rwkw. I wouldnt even bother changing it for 400rwkw.
Good point, sry just got caught up in your posts. Well I'm going from a VL commodore to an R34 GT-T, so, there 'might' be some similarities, as the VL had the RB30 and the R34 the RB25neo. Yeah sry mate, just getting a tad overzealous, I did in fact read the first post. I've been reading a fair bit the last two weeks on this forum, so I kind of gathered power FC was an ECU, I asked only to make sure...
just to confirm, the bosch 040 will be sufficient to hold the power? how much can it take? as im about to buy one now.
just orderd a set of the Aerospeed cam gears on the group buy as well.
edit: never mind im actually going the nismo or tomei fuel pump for safety.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
