offnsv: have you got a part number for those injectors? thanks
ill stick with the nismo pump option then since i can do it myself lol.
can someone explain the difference between poncams and cams? or are they the same thing?..
if i could save money on just using cam gears to hit my power level it would be better for me as i could get some rims.. LOL
'Poncams' are simply a model of camshaft produced by Tomei which are designed as a straight drop in upgrade on a stock RB26 head with no modifications required.
  • Replies 45
the part number on the box was 63500 700cc
with the tomei poncams. im searching them now there is 2 types:
Type A - 260/252 9.15mm
Type B - 260/260 9.15mm
which is the one im after?. im after response.
ive already purchased cam gears from the Arospeed group buy, so i can just get the poncams on its own?. or is it needed to have the specific tomei cam gears with it?
shopping list going to begin in a week or 2 :santa: ive decided im just going do everything right once:
- apexi power fc + hc
- nismo fuel pump
- sard 700cc injectors
- tomei pon cam (type A/B)
- Arospeed cam gears.
that should keep me happy for the rest of my ownership of the R :thumbsup:
Power FC --- good idea.
Sard 700cc injectors do bolt in, it's easy enough.
A factory GTR pump direct wired does the job but, a new one isn't a bad idea.
CAMS...
If you are going to do cams, budget for some dyno time to get them right. Also buy new cam bolts , necessary gaskets,
AND be ready to buy shims. Tomei cams are as bolt in as you get for a GTR but, worn shims on an old motor mean clearences might not be within factory range. You can get lucky, I was and so have a few others (then again I'm not sure if they checked the clearences) but, don't count on it. Shims can cost you a few bob if you end up needing them. Only down side to solid cams.
Those cam gears will work with the tomei cams. I would consider the 260/256 setup for your goals and try and tune the power to reach the 300rwkw with the least amount of rpm and boost. The twin 260's will give you extra in the higher rpm but, you don't want an old motor working up in those rpm ranges to make more power than the old bearings are going to be happy with.
Go the 'Poncam Type A' The 256 with the same lift will grant you enough overlap range to play with for really strong power under 7,000rpm (this is the area to spend your money on).For the first tune, I'd tell your tuner to lop off the power at 280rwkw and focus the tune on squeezing power out of the mid range , bringing it in earlier and trying to reach it with as little boost and rpm possible. It takes a strong will but, make it clear you don't want more power than ' x' but, more mid range and earlier power 'on'. The tuner will be most likely happy not to tune another hand grenade and you will probably drive off with a faster and more reliable car. Getting the extra 20rwkw is a walk in the park by comparison , usually a very small amount of tuning time. I'd drive the car with the 280rwkw for a little while and then go back when you have money to rebuild your old engine.
Don't forget to do your suspension. It makes traction and a lower ET easier too.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
