Hi
I want project for 650 whp for my GTR34 V specII 2001 WITH OUT feul system !!
what is your opinions ? :P
please : but who is know with details !! injectors,,metal head with size??
intercooler size 2 ROW 3 ROW ,,
cam shaft (gear) lift & duration ...etc :O
and what about Apexi cam shaft 264 !!!!! lift I think 10.25 & from A better same camshaft with duration
AND lift OR DIFFERANCE ??? WHY :(
Thank you .
https://www.sau.com.au/forums/topic/164554-prject-650-whp/
  • Replies 84
ok...
i guess your 1st language isnt english...
are you tring to say you only want to run pump fuel? (fuel you get from ur normal petrol station).
and you want to run 2tanks? or are you asking you can run an intake fuel pump, and (or) an out of tank fuel pump? (maybe surge tank?)
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049707
in for page1
ok
I mean change feul pump high pressore ,, injectours,, regolator metal,, turbo intercoler but i want fuel pump
in tank 1 or 2 I can that it ? or not .
GTR MINE's i think don't fit feul system !!! 600 whp !!
my gtr34 fit it intake system greddy complete exhaust . twin plate clutch nismo G MAX BLWOF VALVE HKS
x 2 .... twin exhaust manifold only ... :P
and my idia canceled up pipe for the turbo !!
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049700
ok...
no no this is parts i fit it in my gtr only ...
but I mean i can fit it feul pump in gas tank !!! 1 OR 2 I don't like fit fuel pump out tank !
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049723
can put an 044 intank with a bit of playing around.....
He appeared it is possible that is legal from then she dug you or from your experiment for the arrival to 650 WHP ??
WITH DETAILS !! please :P
and what is your opinion ( Apexi cam shaft ) 264 lift 10.25 ?
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049748
Join today and ask questions without gramma in them, im not sure what this is intended but have to ask do you speak fluent english? Maybe inted your questions properlly, Are you trying to say that you have a 34 gtr without a fuel system, or what is the intended purpose of asking the question, What question are you trying to refer too?
It has no fuel system?
You want to upgrade the fuel system to support 650 rwhp?
What mods do you need for that power?
Maybe start with the basics:
What has the car got in it first?
What turbos, standard or aftermarket?
Best to list the mods it already has in a list form, maybe include a picture this will help :P
Aswell as where abouts are you? Australia? Are you on school holidays
Before we can help you you need to help us
Thankyou
Adam
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049766
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
