  • Replies 84
no from KUWAIT .....epolly nike name !!!!!!!!!!!!!!
Ye, i realise your from Kuwait (ive checked just to be sure)
But you really need to use good english.
If we dont understand what you are talking about, then we really dont have much hope of helping you.
My suggestion would be to talk to other people over there with big powered cars.
Or workshops over there that perform these modifications.
I think they will understand you far better over there as you'll be able to use you native language :closedeyes:
By the sounds of it, find a mechanic in Kuwait, and give them lots of money.
I think they will understand you far better over there as you'll be able to use you native language :D
I think is it in Australia is better tune for the GTR !!!
and not subject of money !!! :closedeyes::)
What the? I've read some weird stuff on here..
But this thread is just too much..
Lets sort this out..
1: Maybe the first thing you buy for your car is a language converter!
2: You may need to buy (if it exists) an Ozzy male petrolhead slang version! lol
3: Then you can translate into real english!
4: Then you will get some staight answers.
5: After you do steps 1-4, we might understand each other
Just a thought!
Just a thought!
Ok
I what I want project (650 whp) for the GTR34 ? only
drag street !
so do you want 650hp or rear wheel hp or 4 wheel hp ?
ill assume rear wheel horsepower, so 480awkw
look in here
http://www.skylinesaustralia.com/forums/in...showtopic=93880
plently of high powered GTR's and all of their mods listed with dyno sheets
look in here
I suggested this earlier in the piece. Dont know if he has read any of it or not.
can a moderator please do an ip check
i think we are being taken for a ride
this guy joined on friday
you have been given all the info and links you need
you just need to read up on it and go from there
If bkc continues to spam useless poorly worded questions, his topics wont last around here anyway. :nyaanyaa:
I reckon we give him a break and someone please refer him to a more internationally orientated skyline forum. Yes on this forum there are people to answer his questions but I dont think we have the patience, specially with BAMR33 giving him lots of nissansilvia.com bullshit.
We have givin him nothing compared to what ns.com would dish him out.
I will try a straight answer, guessing what I think he wants.
650 bhp (that’s at the engine)
700 cc injectors (any Jap brand will do)
Single Bosch 044 mounted in tank (will need a relay and a dedicated wiring harness for 13.8 volts at the pump)
Standard RB26 fuel rail
Standard RB26 fuel pressure regulator
Standard plenum and throttle bodies
Apexi Power FC (no need for DJetro)
2 x standard RB20/25 AFM’s (no need for Z32 AFM’s)
Trust dump pipes
Trust engine pipe
HKS GT2530 turbos
Any Jap brand 264 degree cams (bolt in only, no springs etc required).
Any Jap brand 600 x 300 x 100 intercooler (Blitz is the best value for money)
Around 8,000 rpm will be enough for this purpose
Tuning, tuning, tuning
650 4whp (that’s at the 4 wheels, on a roller dyno)
800 cc injectors (any Jap brand will do)
Twin Bosch 044 mounted externally (will need a surge tank, a relay and a dedicated wiring harness for 13.8 volts at the pump)
Nismo bolt on fuel pressure regulator
Nismo plenum and throttle bodies
2 x Z32 AFM’s
Trust dump pipes
Trust engine pipe
HKS GTRS turbos
Any Jap brand 272 degree cams (springs etc will required).
Will require 9,500 rpm to make the power, plus keep the turbos boosting on gear changes.
More tuning, tuning, tuning
Both combinations will need forged rods and forged pistons, good quality balancing, N1 oil pump, block O’rings, ARP main bearing and cylinder head studs etc etc.
Let the fun continue
:nyaanyaa: cheers :domokun:
'Epolly' what kind of illegal immigrant name is that. Piss of mate, just piss off.
This guys poor english skills aside, your comments are a disgrace, and wont be tolerated here - Warning issued
Consider yourself lucky I haven't banned you on the spot.
hey guys, he can't speak perfect english... SO WHAT?! it's not because he's lazy obviously it's not his native tongue. I can't speak japanese real well either, but if I tried posting on a japanese forum I bet I wouldn't get arse monkeys with nothing better to do bagging me out for trying to speak a foreign language.
if youy can't be bothered trying to figure out what he wants, or you just don't want to help JUST DON'T POST IN HERE. consider yourselves warned.
as for bkc all of the information is in the forum. there are dozens of GTRs running over 600hp in Australia. we are not all here to serve your specific requests and with your level on english it's pretty hard to figure out what you want, so just be a bit patient.
Apologies to Epolly and anyone on the forum that was offended by my remarks. I was rather wasted at that time (note to self don't make drunk posts in the future).
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
