  • Replies 84
I will try a straight answer, guessing what I think he wants.
650 bhp (that's at the engine)
700 cc injectors (any Jap brand will do)
Single Bosch 044 mounted in tank (will need a relay and a dedicated wiring harness for 13.8 volts at the pump)
Standard RB26 fuel rail
Standard RB26 fuel pressure regulator
Standard plenum and throttle bodies
Apexi Power FC (no need for DJetro)
2 x standard RB20/25 AFM's (no need for Z32 AFM's)
Trust dump pipes
Trust engine pipe
HKS GT2530 turbos
Any Jap brand 264 degree cams (bolt in only, no springs etc required).
Any Jap brand 600 x 300 x 100 intercooler (Blitz is the best value for money)
Around 8,000 rpm will be enough for this purpose
Tuning, tuning, tuning
650 4whp (that's at the 4 wheels, on a roller dyno)
800 cc injectors (any Jap brand will do)
Twin Bosch 044 mounted externally (will need a surge tank, a relay and a dedicated wiring harness for 13.8 volts at the pump)
Nismo bolt on fuel pressure regulator
Nismo plenum and throttle bodies
2 x Z32 AFM's
Trust dump pipes
Trust engine pipe
HKS GTRS turbos
Any Jap brand 272 degree cams (springs etc will required).
Will require 9,500 rpm to make the power, plus keep the turbos boosting on gear changes.
More tuning, tuning, tuning
Both combinations will need forged rods and forged pistons, good quality balancing, N1 oil pump, block O'rings, ARP main bearing and cylinder head studs etc etc.
Let the fun continue
:banana: cheers :banana:
OK .
Thank you very much.
but I need to know the size meatal head gaskit for project concering (650 4WHP) :P
also my car (D JETRO )!!!!
you are big problem !!
you have babmpers kkkkkkk
you are baby :3some:
shut your mouth . :spank:
Relax - no offence meant to you, just an in-house (in-Forum?) joke about the use of D-Jetro.
It is the preferred version of 2 or 3 tuners in the West of Australia. On the East side the L-Jetro is more commonly preferred by tuners.
I use a D-Jetro on my setup (see the RB26 upgrade thread as previously recommended for my specs).
Cheers
Gav
Edited by Gav
D JETRO version of PFC is better and more response !! :D
100% rubbish.
DJetro is a band aid for people who can't be bothered finding the right sized AFM and for tuners who give up because they can't cure reversion.
I use this car (VMax) as an example often, it uses a Power FC and AFM's, makes well over 1,100 bhp and runs 8's at 160 mph.
:( cheers :(
100% rubbish.
:( cheers :D
you know what is Difference between L JETRO and D JETRO ? :D
Thanks . :(
650 4whp (that’s at the 4 wheels, on a roller dyno)
2 x Z32 AFM’s
Trust dump pipes
Trust engine pipe
HKS GTRS turbos
BUT I need size meatal head gaskit for the project ???
Thanks all
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
