You take the unit out, then unscrew the front of it. the blubs are set in a little clip which unscrews and you can take it out. Good luck finding new blubs to fit, mine has been blanked out for a while now because I haven't been able to find new ones.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3050152
i believe there was someone doing a group buy of different colour led's on the GB thread so maybe do a search and see if he has them yet? they were gonna be in white (std) blue amber and i think green? had a few pics of them installed in gtr dashes adn looked the goods, so might be worth sussing out?
cheers oxford
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3051152
Jump on the Yahoo auctions. There are quite a few kits on there for them. Most of them seem to be blue though, but if thats not a drama (wouldn't be for me) have a look.
http://page10.auctions.yahoo.co.jp/jp/auction/m39813386
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3051798
I got bulbs for mine from dick smith in brisbane city, can't remember the part number but they were tiny 12v bulbs. I just took the ones out of the car into the shop and compared them. They came with wires on them already which i stripped to bare wire to put in the unit. That was about a year ago and they have been perfect ever since. If you do go ahead, the stock bulbs have little blue sleeves over them which are very fragile, try not to damage them when you take them off so you can re-use them.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3053314
cool!! why didnt i think about Dick smith!! BTW is it hard to take out the front panel of the climatic control?
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3053891
No Yudi, it's very easy...
Just use the guide for removing your head unit, and once you get the whole section which holds the stereo, guages and climate control panel out, it'll be easy from there.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3059320
Ohh oK thanks Nick. That shouldnt be a problem since i change the headunit myself. THanks again. This Led light have been bugging me since i got the car almost 1yr now. Geez thats quick 1 year already. I dont think i will ever sell the car, it will be a ripper in abt 10yrs.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3059386
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
