Hi all. Very soon now I will be getting my 3" turbo back exhaust.
I was just reading through the meggala site and noticed that the car will run really rich once this mod is done.
What Im asking is it then necessary to get one of these SAFC to control this richness or is there another way. Does it actually cause any engine damage?
I will eventually get a SAFC but prob not for a year.
https://www.sau.com.au/forums/topic/16458-safc/
  • Replies 41
So it will be alright getting the exhaust done without the SAFC although one would obviously be beneficial?
I have only seen the APEXI SAFC II's that seem to sell for $500-700.
Are there any cheaper SAFC to choose from and what are the costs associated with installing one of these.
Also, once I get the exhaust, would it be beneficial to get a dyno tune or just resest the ECU
https://www.sau.com.au/forums/topic/16458-safc/#findComment-338660
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
