  • Replies 41
Thanks mate. Your responses are as fast as your car.
you can just see pauls head gettin bigger :D
what steve said is right, put the exhaust on and have a quick dyno run to check the AFR's. if theyre rediculously rich then maybe consider an AFC. you can get one of the older series ones for around the $150 mark
https://www.sau.com.au/forums/topic/16458-safc/page/2/#findComment-339418
I can't say that the map I used when going to the dyno was any evidence of a good tune. My afr's above 120kmh in 4th were super rich. I did mean to make them that way to minimise the ping issue. Otherwise the afr was around 12 which aint bad for a road tune.
The dyno resulted in 230 something HP at 130kmh, whatever that is in rpm (I am guessing 4700rpm) before the ping comes in.
I've got a 600HP fuel pump in now and things seem a little better coming onto the throttle than before too.
https://www.sau.com.au/forums/topic/16458-safc/page/2/#findComment-341338
aftermarket management would be the way to go and possibly a boost controller, then before u start playing with bigger turbos, have to consider, upgrading fuel system, and rebuild engine with stronger internals so it can cope with the power level and higher boost levels that bigger turbos produce :)
if you don't want a full on ecu, get an apexi safc or safc II which is a piggy back air fuel controller, i just got mine unitl i can afford a full on ecu :)
adrian :P
https://www.sau.com.au/forums/topic/16458-safc/page/2/#findComment-346824
adrian, how much did the apexi safc2 cost you and what better performance are you getin out of it?? Wheres the best place to buy one from and who do you reckemond to work on cars, i took mine to Tim Sleko to get a GFB boost controller put on (now at 10 psi), and take off the fuel regulator cause it was running too rich.
Matty P R34
https://www.sau.com.au/forums/topic/16458-safc/page/2/#findComment-348362
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
