I HAVE PURCHASED A 96 GTS-T SII,
I HAVE A 3" EXHAUST, A TURBOSMART BOOST CONTROL, APEXI POWER FC W/ HAND CONTROL.
NOW I WANT TO UNGRADE MY TURBO. IS THERE A COMPLETE BOLT ON TURBO KIT OR CAN I JUST UPGRADE THE TURBO ONLY?
THANKS FOR YOU HELP.
https://www.sau.com.au/forums/topic/164584-which-turbo-to-geta-little-help/
Yeah if you want a full upgrade turbo kit you can go the HKS GT-RS or if you want something a little cheaper you can got for one of the Slide High Flowed stock turbo's, some of the people on here have had some pretty good results with them .
but its limited to what 250 rwkw ( n is that straining? )
incase u wanna put more mods bigger power even for a show u can keep da garrets for more power..up to him but for an exdtra 3-400 he wont ahve to buy a brand new one when n if he goes over the 300 rw but thats if he is...
i dunno thats what i thought but i could be rong
Need to know you power goal or intended usage before making suggestions.
zas, either a high flow or t28 based turbo is going to be limited to 250-260 rwkw anyway. For more than that a gt30 sized turbo is needed and they start about 1700 new.
On top of the 28 based turbo price you would need lines, adapters and possibly a revised dump so the price goes up.
Best bang for buck would be a slide highflow, best bolt on option would be a gcg highflow (this is my opinion based on running a gcg highflow followed by a similar sized non bb turbo on the same engine. The transient response difference is huge at small to mid throttle openings even though full boost hits about the same time), for more than 260 start looking at 3071's and 3076's for 300 plus
if you want over 300rwkw (comfortably i know theres ppl running stupid amounts of boost with gt28xx making over 300) you need a gt30 series and theres a lot of other mods needed aswell, whats your power goal wizlb
I want the KW @ the wheel to be 225 to 260.
Do you guys think I should get a complete bolt on turbo kit or a turbo upgrage, and if I just get a turbo upgrade will I have to do or get anything else for the car...ie..manifolds, cat back, dump pipes, things like this.
Thanks for you help ppl!!
Thanks for the info guys.
Now just a little more help.
I have settle on a Garrett GT2860R, but is this a bolt right on turbo for the 96 gtst sii?
And if now what else will need or should I get a garret turbo kis?
Better going the Garrett gt3040 as this will be able to get what you want then injectors then fuelpump then plenum then traction and suspension the brakes good luck With these turbos most will bolt to the factory manifold just need aftermarket lines the gt28 series will bolt up fine the 30 series depends what one u go for and you should be ok
Cheers
A
GCG Hi-flow.
http://www.skylinesaustralia.com/forums/in...=121128&hl=
Direct replacement for your stock turbo. 250rwkw.
Dont need no "kit" thats 3k. Just a few hundred in labour
Too easy. ;)
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
