Hi guy's I was wondering if anyone had experienced this before.
Some where in the driver side I occasionally hear a rubbing noise when I go over bumps, although my car is not lowered, its not the wheels rubbing on the guard, its only on the driver side and usually occurs in the wet although sometimes in the dry. It doesn't do it all the time.
I don't feel anything different in the steering wheel, its just normal. I jacked up my car and had a look underneath and I couldnt see anything loose or wrong. In a way it could be my bushes although I've never had to change bushes so im not sure.
This morning it was making the noise when I went over bumps on the road, and I noticed when I went over speed humps the noise was delayed. What I mean is it did it after the front wheel had gone over the speed hump.
What do you guy's think???
:rolleyes:
https://www.sau.com.au/forums/topic/16460-squeeky-rubbing-noise/
do the old "push and watch it bounce" trick to see whether its the shocks.. mine got to a "clunking" stage in my old car, every bump "clunk" till i got them replaced.
If its not that, could be the suspension bushes like you said..
u can drive with no shockers you just bouce all over the place over bumps...so yes..
the noise is annoying isnt it, but the car should last for a long while yet. When you start hitting bumps and the car just really bumps and sort of lifts off the ground then maybe you should consider changing it. Im just leaving it for now, ill probably change them when i get bigger wheels which is a long way away so i guess just live with the noise for now.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
