Hi guy's I was wondering if anyone had experienced this before.
Some where in the driver side I occasionally hear a rubbing noise when I go over bumps, although my car is not lowered, its not the wheels rubbing on the guard, its only on the driver side and usually occurs in the wet although sometimes in the dry. It doesn't do it all the time.
I don't feel anything different in the steering wheel, its just normal. I jacked up my car and had a look underneath and I couldnt see anything loose or wrong. In a way it could be my bushes although I've never had to change bushes so im not sure.
This morning it was making the noise when I went over bumps on the road, and I noticed when I went over speed humps the noise was delayed. What I mean is it did it after the front wheel had gone over the speed hump.
What do you guy's think???
:rolleyes:
https://www.sau.com.au/forums/topic/16460-squeeky-rubbing-noise/
do the old "push and watch it bounce" trick to see whether its the shocks.. mine got to a "clunking" stage in my old car, every bump "clunk" till i got them replaced.
If its not that, could be the suspension bushes like you said..
u can drive with no shockers you just bouce all over the place over bumps...so yes..
the noise is annoying isnt it, but the car should last for a long while yet. When you start hitting bumps and the car just really bumps and sort of lifts off the ground then maybe you should consider changing it. Im just leaving it for now, ill probably change them when i get bigger wheels which is a long way away so i guess just live with the noise for now.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
