Ok, 2 things. Firstly it is probably something rubber on steel. Secondly, if it's worse in the wet, that indicates that it is something exposed to the elements so unlikely to be internal parts of your shock absorber (it is possible though, you might just notice it more in the wet).
Look for areas with steel and rubber contacting. Off the top of my head I can think of suspension bushes, shock absorber bushes, and the bump stops on top of the springs. Spray anything suspect with some sort of lubricant. I would think WD40 would be ok, but I'm not sure if that's ok to spray on rubber so check with someone more knowledgeable first.
There was a spray that a mechanic used to get rid of a squeak in my bike's suspension but I can't remember what it was. I think it was silicone-based.
Jimx thanks for the input, I will definetly look into that. I did ask pedders about the condition of the bushes and they said everything is fine. This is so wierd, I wish i knew why it was making that noise. I would think sometimes that something is rubbing although i sometimes squeeks which cant be something rubbing.
Thanks again Jimx
i had the same problem b4
but i fixed it.
It may be because of an imbalance in the car causing too much
stress on one of the shocks.
Before i had my 12 inch sub mounted on the side of the boot which was realli heavey.
After moving it to the middle the noise was gone.
And i know for a fact that the noise came from
the front passagner suspension.
Hope thats helpful...
thanks for the info mate, its very helpfull although mine does it on the drivers side in the front wheel and if that is the case im not sure what could be causing the stress on the front shock coz i dont have anything that is heavy in the car, unless its my weight hehe
dont think so
hahahah. i know what your problem is, i get it too.
i have some fat tyres on the fornt 255's and i also have low suspenson, its stiff as shit, and it rubs on hte plastic gaurds that are inside your 1/4 pannels.
check the plastic and u will see rubbing marks.
hope this solves your problem.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
