Ok, 2 things. Firstly it is probably something rubber on steel. Secondly, if it's worse in the wet, that indicates that it is something exposed to the elements so unlikely to be internal parts of your shock absorber (it is possible though, you might just notice it more in the wet).
Look for areas with steel and rubber contacting. Off the top of my head I can think of suspension bushes, shock absorber bushes, and the bump stops on top of the springs. Spray anything suspect with some sort of lubricant. I would think WD40 would be ok, but I'm not sure if that's ok to spray on rubber so check with someone more knowledgeable first.
There was a spray that a mechanic used to get rid of a squeak in my bike's suspension but I can't remember what it was. I think it was silicone-based.
Jimx thanks for the input, I will definetly look into that. I did ask pedders about the condition of the bushes and they said everything is fine. This is so wierd, I wish i knew why it was making that noise. I would think sometimes that something is rubbing although i sometimes squeeks which cant be something rubbing.
Thanks again Jimx
i had the same problem b4
but i fixed it.
It may be because of an imbalance in the car causing too much
stress on one of the shocks.
Before i had my 12 inch sub mounted on the side of the boot which was realli heavey.
After moving it to the middle the noise was gone.
And i know for a fact that the noise came from
the front passagner suspension.
Hope thats helpful...
thanks for the info mate, its very helpfull although mine does it on the drivers side in the front wheel and if that is the case im not sure what could be causing the stress on the front shock coz i dont have anything that is heavy in the car, unless its my weight hehe
dont think so
hahahah. i know what your problem is, i get it too.
i have some fat tyres on the fornt 255's and i also have low suspenson, its stiff as shit, and it rubs on hte plastic gaurds that are inside your 1/4 pannels.
check the plastic and u will see rubbing marks.
hope this solves your problem.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
