Just read an artical in todays (april 15) hearald sun on page 22 car rally angerys traders.
this atical tell us that the prosch club (i believe it would be prosche owner club vic) has being given permision to close the great ocean road between lorne and skenes creek for 2 days to allow then to "take in the ocean view" more like to fang it as hard as pserble as no one will become the other way :thumbsup: .
personaly i think it is a joke, why should the GOR be closed for 2 day for a rich man's club (imo) when other club's use the road with other traffic. plus there is the small bussness that will be affected due to this move, altho they will raise an exspected $80-000 for the hospital. :D .
i am trying to assertain if it is the porsche owners club vic that is running this event.
chears brentt
https://www.sau.com.au/forums/topic/164604-car-rally-angers-traders/
You do get a lot of things to happen when you are running charity events than when you are doing it just for the club. I'm sure if SAU could run an event that would make $80K for a good charity we could get doors opened and roads closed too.
damm there goes my spelling agan.
spellchecker is your friend, you should really consider using it :bunny:
as to the actual topic, it's all about the fact its a charity event.....anyway, having more club type run car events around will show the public what we are all about and we aren't 'all' just a bunch of hoons....
i've heard they do a similar thing on the great ocean rd, unofficially. basically get a car to go ahead and basically be a saftey car, and i would suppose on a stretch of rd that has no entries to it. Radio back saying all clear, no cars on the road, and then they can do timed runs, giving it full stick and using both lanes.
Or just use their lane and report back that there isn't any camera's, etc... who knows, urban legend maybe
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
