many late nites researching this forum and many overtime shifts at work got me my parts...and ive only added half of it. Kinda hoping i would get some feedback from people that have actually had their engines rebuilt.. When everything is done and up and running then i'll came back to this thread and add my experince and hope it will help someone else in the same boat
  • Replies 44
how come nobody goes to an engine builder directly and only recommend workshops who in turn palm some of the work off to their machinists?
surely it would be cheaper to go directly to the one place and cut out some of the middle man?
Im not stating anything, im curious to know
There is virtually no Japanese performance workshops in Perth who do everything in house.
XSpeed, Hyperdrive, Top Racing , CRed, Speedworks, Ovaboost , In Tune all outsource the head work and engine machining.
All the above workshops then assemble the engines in house to there own specifications which vary with each shop.
The engine machining and tolerances supplied by the workshop is one of the critical factors in engine life and building one to go racing and will be refreshed after every season is different to building one that is in a street car.
The only shops that machine AND build engines are very limited , both in quality and there desire to involve themselves in turbo cars. Most of these shops deal with V8's such as Kostecki, Kendrick, Repco, Veems , Performance Automotive plus others I can't remember.
Cheers
Ken
ahh so what youre saying is you tell the machinists the clearances/tolerances required for the block depending on pistons chosen, head w/ squirter sizes etc and theyll do what theyre told, otherwise theyd be having a stab in the dark?
that makes sense since it isnt common knowledge
thanks for clearing it up ken
Cheers
Ken
you forgot to mention nobody will touch any head/block that has had work done elsewhere and needs assembling :blink:
  • 8 months later...
Hmm,
I decided to do my RB25det myself...
Find out a bucket load of stuff that I never knew about engines too...
If you have the motivation, and the time give it a shot... I found that building the bottom end all the stuff has to be perfect (obviously) but yeah as long as you can find out all the specs for the block, and pistons etc, take the bottom end to the machinist, with the clearances etc, and they will set it all up for you to those specs..
But yeah if you got the money to spare give it to someone else.. I am interested in this sorta stuff, as my full tme job is in a completely different field..
I got accesss to a workshop where I am working on the engine evry day from 3 till about 6.. except I have access to it for half day on sat as well.. Having the support of a mechanic (mind you he does bmw's and merc and all the euro cars) he is still able to give me some pointers.. There is enough info on Skylines australia to be able to do all this, there is torque settings, all the measurements etc, to be able to do everything..
Will let you all know when it is finished, but so far the pieces are falling into place.. But yeah I am glad I decided to do this, as I have only one person to blame if something goes wrong... But yeah I know it won't...
Cheers..
Edited by maka
  • 2 months later...
got my r34 in at top racing. rb30 bottom with the NEO head. Engine came back from engineering last week so steve should start bolting it back togther this week sometime. I went all out on this project for big power. t04z (1.00) a/r with 2bar should see 650rwhp....Haven't factored the NOS system either :)
other mods:
poncams 260
greddy plenum
port/matched/polished head
sard 1000cc
cp pistions ceramic coated
argo rods
fulyy balanced
HE sump
ati balancer
plus much more
yeah hence my 1st post saying if ppl have actually gone to an engine builder.. seems like no one has!
As stated, nobody in Perth does it all themselves.
I just had mine rebuilt and found these guys to be exceptional:
Headwork: (re-shim for 270 deg cams, 10.8mm lift, and fit new guides/springs, assembled and decked -- $1100)
Applied Automotive - John St, Bentley.
Block machining (re-bore to 86.5mm, acid dip, etc etc -- ~$1000:
Performance Modifications - Osbourne Park
or
You can use these people direct, then take your machined block and assembled head directly to any workshop in Perth, and they will build it for you. There is nothing magical about building a motor, and no reason you couldn't do it yourself with the right tools, time, and patience.
People who I've seen build motors which stand the test of time:
Ant Scali (X-Speed)
Sean Keating (All-Star Garage)
There you go, thats all the advice I can give you. Coming from someone who's just built a motor (and made over 530hp at all 4 wheels) it might have a bit more substance than someone telling you that you should use their workshop because they're yet to try anywhere else and thats the 'only place they trust with their car'.
i wonder how much i would of saved if i took the head and block directly to the associated workshops. As with one of the workshops mentioned, was told of 3 month waiting period. Although my repeated calls were never returned and got the cold shoulder ended up at top racing. Also good to go to the different worshops and have a chat with them. Have a look at how the shop is run and the people that work their should give a indication as to how good they are
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
