Hmm may have to fire up FAST and order some parts.
Thanks Fellas!
i have a full list of parts required if you need them...but back at the workshop and i wont be back there until tonight. If you have FAST it will be a snack.
Funny thing is most of the bits are cross referenced to the Nissan Navara...lol
So I just found out lol
All of them bar 1 washer they have in stock and can pick them up at 2pm :D grand total a whopping budget crusher $14.50 most expensive part was a washer at $5 even the stud was $2.50
Cheers
Cheers
ahh yes thats right...last time i ordered a set i also ordered an oil pump gasket and a seal...= $30
its laughable that this type of insurance is so cheaply aquired but so often overlooked.
Well,
I finally got the top of the Head back together, and strted the car... Guess what the sounds still there.
I am scratching my head to what it could be! Its running fine, Revs fine, No smoke no missing nothing out the breathers just a god awful tapping sound coming fro mthe top of the engine.
I recorded a lil vid with the sound, be aware some of the noise is the clutch shaking from the low idle so I will post that as soon as its uploaded.
http://au.youtube.com/watch?v=WcZGD8DdbGE
Edited by murrayis
Well,
Sounds like rod knock to me. Forgive me for not reading through the thread, but have you confirmed that it's not rod knock?
It could also be piston slap, I had a bad knock noise from what I thought was my head after going to the track once. I could have sworn it was coming from the lifters... I rebuild them, put them back in, and the noise remained. A couple weeks later the motor started smoking really bad, and I took it apart and found a destroyed piston, I'm pretty sure the noise I heard was piston slap.
Good luck, hope you resolve it.
-Max
Roy, Oil pressure was perfect and stable.
We pulled the head of this afternoon and this confirmed my nightmares for the last couple of weeks....
Number 1 has Hit the Head, We pushed on each piston and when we got to number one it moved down a mm or 2 :-(
So we will be pulling the res of the motor out tomorrow to strip it down and see what in the world went wrong, But its sounds like the little end thats kuput :)
Well I dont have much to say but yea the pictures will Explain it.
post-23119-1232950674_thumb.jpg post-23119-1232950731_thumb.jpg post-23119-1232950863_thumb.jpg
Have to replace:
- Crank
- Bearings
- Maybe 1 rod, should be fine hopefully
If anyone know anyone who works for nissan and can get me a R33 GTR crank at a good price and they let me know, it would be greatly appreciated.
Cameron
RB30 cranks and blocks are only like $100.. :)
Sorry to hear though dude, good luck!
ive thrown RB30 blocks and cranks out...lol
got another whole engine given to me the other day because i wanted the oil pump housing off it.
dont go RB30...only wankers do that. :D
ahh only shit stiring...im doing a RB25/30 very soon. CP pistons, Argo rods, N1 oil pump, 270 deg cams, TO4Z with a 1.0 rear housing, stainless Jap manifold, Tial external gate, plazmaman plenum, 740cc injectors, Hybrid GTR intercooler, vi-pec ecu, C4 auto etc. Ive got most of the stuff...just got to screw it together
You will have no idea what we are putting it in.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
