No damage to the heads its perfect. thank god!
Bore is fine in all 6
Oil pumps fine, so just need a crank and bearings and get the number 1 rod checked over.
Dirt Do you know if mark would have any R33 rb26 cranks he would sell?
Cameron
Number 1 has Hit the Head, We pushed on each piston and when we got to number one it moved down a mm or 2 :-(
So we will be pulling the res of the motor out tomorrow to strip it down and see what in the world went wrong, But its sounds like the little end thats kuput :)
How has the post-mortem gone? ie I would want to know exactly what caused the failure since there had been no contact between piston : head.
If the bearing is only gone for #1 I'd probably concentrate there first.
Oil pressure may have been fine, but is there any chance of a blockage in that journal?
Alternatively, maybe have a close inspection of the piston, rings, lands etc and look for evidence of knock. I'd think that detonation/knock serious and prolonged enough to cause bearing damage would have seen similar probs throughout and not confined to #1.
Well,
We spoke to Liddles Head Shop yesterday regarding this, AS he's who I turned to to check the cam shafts over. And he seemed to think that the main bearing would of let go due to the timing belt becomming so tight and putting too much force on the top bearing surface as the bottom surface on the number 1 main bearing is pretty much fine all the damage is mainly to the top side.
Main bearing 1 and the big end bearing on number 1 are the only bearings that are rooted.
We did inspect the pistons and rings and they all look perfect the rings look like they were running in nicely! We only going as far through the tune doing the base fuel tune/fuel pressure adjustment and 2 first full runs to 6500rpm held a nice 11 - 11.5 Ignition timing hadn't really been touched and there was no sign of detination.
Tomorrow we are goign to be re-checking the tollerances etc to make sure all that was spot on but we double and tripple checked it before it all went together.
The Oil journal is all clear no blockagepouded some oil down there and flowed through without any problems.
Cheers
Cameron
ive thrown RB30 blocks and cranks out...lol
got another whole engine given to me the other day because i wanted the oil pump housing off it.
dont go RB30...only wankers do that. :(
lol :D
My crank cost me $100 because I couldn't be bothered taking the engine home to pull it apart just so I could take the crank back to be ground.. so I just paid the guy to take it out for me seeing as the crank was technically already where it needed to be :rofl:
P.S. 3L torque ftw!
P.P.S. fair enough cam, I know what you've put into this engine so it'd be nice to see it all the way through! good luck bro!
Guys I have a fairly similar noise in my RB25DET and ive been scratching my head to figure out what it is. Heres the story
The motor itself hadnt been run for nearly 2 years. It was off the road for a build im doing to my 180sx. In this time I had the head off the motor, poncams professionally installed in said head and I bolted it back together with a new genuine gasket and ARP head studs.
A workshop got the car running and noise very similar to Camerons appeared. The workshop assured me they primed the car off the starter motor first to build oil pressure.
I havent checked that much myself so far, just a simple compression check which all came up fine (shouldnt be bent valves etc)
The wierd thing is, if I run the car for a while and take it up n down the block for example then the noise goes away. It only seems to be audible for the first 5 or so minutes the car is running.
What would this indicate? From my knowledge you will always be able to hear a bearing failure in a motor correct? Once they start they will not go away?
Thanks man. Should have included this in the original post but oh well..
The bottom end was left completely standard the whole time. It is an 80,000km bottom end and the noise wasnt occuring 2 years ago when I heard it running before purchasing the halfcut. When I had the head off the bores were spotless as well.
EDIT: I did turn the bottom end over by hand maybe a total of 30-40 times whilst the head was off. Would this have caused any damage to the bearings do you think? I had drained the oil but I thought there would still be residual left overs to keep things lubricated. It would have been turned over after just over a year of not moving.
Edited by rinmak
Well just got the number 1 rod back from Bryants Engineering in Sumner Park from being resized, they had to take 2½ thou or 0.063mm off it. I am hopefully picking up a R33 GTR crank this weekend. So the plan is to have it back together and in the car running before March :huh:
Well I need some Advice from all the knowledgeable people on SAU, I have no idea what would cause the following which I found today when I had a chance to finish pulling the block apart:
Oil pump:
Thrust bearing:
Another Issue I can see if with the clutch, Is there smaller throwout bearings for the GTR box? as I can see its not wearing in the same position as it previously was.
Edited by murrayis
Hey
get a impact driver and remove the srews holding the backing plate on the oil pump.
then have a look in there to see if the pumps shagged?
i would be getting a new pump personally regardless due to the chance of it being the cause of this, and also
the chance of it having metal filings in it.
Quick Update - Had some time today to start assembling the block, Spent 2½ hours this morning cleaning the block with a toothbrush and 4 ltrs of part cleaner. Installed the new ACL bearings lubbed them up nicely installed the crank and torqued the cradle down nicely.... moves so smoothly compared to the other one you needed a spanner to turn the crank.
Also cleaned up the pistons and installed and torqued them down to spec.
Hopefully tomorrow I will get time to install the pumps and sump then its just a matter of bolting the head back on and back to the dyno we go. I'll post some pics up tomorrow afternoon after I'm done with it.
Eye of the tiger, most people would have just given up and moved on. :)
Hey what did you find with the oiil pump? was it caused by the thrust bearing allowing the crank to move forward? If it was i would just double check the end float on the crank (thurst bearing clearance) so it doesn't happen again. Good Luck you Deserve a good motor after what you have been through
Thanks for the comments.
The old bearing have all been tossed out, We expect it was end float and part of the bearing rubbing on the back of the oil pump as it went past it.
To fix it up from the misshap I have had number 1 rod Resized 2½ thou, replaced the crank, had it machines to the correct clearences for what we want to rev it too and installed a new set of ACL Race series rb26 bearings for both mains and big ends.
Edited by murrayis
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
