Does anyone know where I can get -10 black braided line? doesn't have to be anything special it's just for the breather lines.
I have found Pro Lite 350 Hose Has anyone had any dealings with this? Or know a good supplier as most prices I can find are around $60/Mtr
Edited by murrayis
  • 1 month later...
Ok a little bit of an update, Finished setting up the Haltech e11v2 and installed finally the Oil Catch Can setup.
Tried to turn it over today on what Haltech said should get it started as a Base Map not expecting it to fire and it didn't few nice Backfires and I decided to leave it at that
If anyone has a Map for a Haltech e11v2 for a rb25 with 750cc injectors I would be very grateful if I could get a copy to see if I can get the car running before I book the dyno and the tuner.
Anyway here is a quick Pic of the engine bay as it stands now.
Wheezy,
You are correct with a BMI 80mm Throttle Body.
Does anyone know what the firing angles for a rb20det are? I have them when I used a wasted spark setup but now I have the haltech I am not sure what the firing degress are.
Cheers
Cameron
Edited by murrayis
Wheezy,
Cheers
Cameron
120deg for an inline 6 IIRC?
Thats what I was thinking, I'll double check this with Haltech tomorrow just want to make sure as it seems when cranking to be popping weird as if the timing was all wrong.
Also need to get the type of CAS and if its on the Rising or Falling edge etc, I miss my Adaptronic where you could jsut tell it the engine and away it went lol
Cheers
Cameron
How do you find the KU plenum for response against the factory intake manifold? How is your top end also. I ask because I have one and have not spoken to anyone else who uses one on a 20. I just wanted to compare thoughts. Obviously the 2.4L will be a bit different, but close enough I guess :)
Wheezy,
Not having it fully tuned yet, results were pretty much as we expected its fairly responsive and flows plenty in the top end however I did port the manifold out to match the head and I also have 270 degree Cams.
Cheers
Cameron
Wheezy,
Cheers
Cameron
Interesting resultes, similarly; with my stock engine, I found it responded the same as a factory manifold but up top over 7,000rpm it keeps making power whilst an other RB20 I have seen with the same turbo drops off.
Cant wait to get some cams in it though.
Good luck tuning it! :thumbsup:
I Hate Tuners.... I spent 20 minutes yesterday trying to get it started, He sat in it turned the key and it fired up instantly!!!
And Yes the timing belt is a little too tight, Will have to back it off a tad.
Thanks again bubba for the Map.
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
