Well.... It's been a busy week, After starting the sump removal process to find oil dripping out the bottom of the gearbox/Clutch cover I decided to pull the motor out and investigate what appears to be the rear main seal leaking.
After the missus telling me to send the motor to somsone who knows what they are doing, I took her up on the offer :( Who could say no to that sort of permission given....
Engine is now on its way to Red R Racing for Paul to have his way with :(
Oh and I found the oil leak, one of the Half Moon Cam Cover seals had fallen/blown out...
Edited by murrayis
Thanks for everyones suggestions, I will take a look at all of them. I'm thinking of also seeing If I can fit the OEM shorud and Fan back on and maybe trim the blades to clear... Just a thought.
sorry for the late reply, here are my results to a 52mm radiator in a rb20 r32. Hope it helps.
http://www.skylinesaustralia.com/forums/52...st-t327859.html
After the missus telling me to send the motor to somsone who knows what they are doing, I took her up on the offer :D Who could say no to that sort of permission given....
Engine is now on its way to Red R Racing for Paul to have his way with :P
R31 House do an aluminium replacement for the rear half moon cam cover seals. Cheap cheap too!
was over at Red R today and had a squizz at your stripped engine, its a bit of a disaster. How the previous machinist chopped up your block was insane. The reliefs cut in the base of the bores with no chamfer has given your piston skirts a hiding and the way the annular groove in the block bearing housing has been done is very messy. From what Paul said it didn't matter how many times this thing was rebuilt, using that block would have quickly destroyed it.
mate looks like a new block, but it appears the crank has survived the carnage and the fella's said it should be ok to use.
i feel your pain as i had a couple of disaster builds before Paul and Terry helped me out. She's in good hands bud.
Edited by blitzxtr
Yeh, beauty of RB20s are that a different block may be free, or $150 or so. :P
Curious to see how Paul goes with the lil RB24. His experience with head porting and playing with different things makes him the perfect guy for a little project like this. So many people I have spoken to re building a 24 just dismiss it and make me want to do it myself..no love for the project :bunny: But I know i dont have the know how....its good to see builders with an interest and pride in what they are doing, hopefully Camerons thing punches out numbers adn exceeds his expectations
Roy,
Exactly my thinking.... If you have a spare rb20 block let me know...
In a midnight conversation with Paul the other night we are thinking 360 - 400kw with the limitation being the flow in the head, The head is already ported so nothing new will be done to it.
Now all I have to do is wait for ROSS Piston to get back to me about the new piston rings & we can get the ball rolling.
Yes I saw said 9800cc engine Saturday night! whoa.......
Things have been delayed a little as I am currently hiding in the mountains of Queenstown for a week while waiting for Ross Pistons to ship a new set of piston rings anf trying to find a new block!
No car pics to update however these may surfice!
Outlook from the snow base:
Halfway down the mountain:
  • 4 weeks later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
