Went the option of billet gears for the pump. Fitted up nicely I must say.
Any idea how much oil a RB20 with external cooler should take? 7 ltrs seemed to be what got the level jsut above full allowing for the oil to fill the lines and cooler.
so what else would u use apart from billet when going 4 a stronger oil pump ? whats standard ?
I think the normal ones are just steel.
I have to hookup my oil pressure guage this morning to see what oil pressure its doing at idle, should be around 80psi yes?
I think with standard oil pump on idle it should be around 40psi ish. when you are under acceleration should go up to about 80psi.
however with the different gear it will probably have greater pressure at idle...
I havent had a chance today to take it for a drive but yesterday when I checked the oil pressure came up around 2000rpm was sitting around 75 - 85 PSI on the stock guage. I'll have to try wire my guages up tomorrow if I get a chance in between calls.
Just took the car for a quick drive around the block, sounds strong.. nothing like a rb20 has the sound of a rb26!
Oil pressure was solid 75 - 85psi, didnt look at the tacho or speedo once... was listening to al lthe clunks I had forgotten about! Hmm Coilovers feels alot different to the 05 Magna I have been driving for the last 2 ½ years!
Onice I get the front bar back on and indicators I'll take it for a longer drive, I am thinking I will have to adjsut the clutch also it was a little rough/hard to go into gears.
Edited by murrayis
Cheers!
I decided it was best I hookup the Idle Control Valve afterall so Spent an hour or so yesterday doing up the 4 bolts that hold it onto the plenum, Should of done this before I put the oil filter and oil cooler adapter on the engine!
Heres a lil pic of the fitting I fitted to the intake pipe just after the BOV and before the TB
Quick update, I havent had much spare time to be able to drive the car so have done a few laps around my area up and down the hills so done around 50km's so far so in total the rings have around 120km's on them so they should be clsoe to run in.
Just took the car for a spin around the block.. OMFG!!! didnt go over 0.6bar and used about 35% throttle to hold it there but...............wow! I havent felt that feeling for 2 ½ years, pulls a hell of alot harder than the rb20 did on 17psi and 100% throttle only took it too 5000rpm but dam! was scary :D :D hope to get it on the dyno next weekend to setup the boost controller and adjsut the afr's a tad noticed they were sitting around the 12.8 - 13.3 mark.
Its going to lag a bit makes positive pressure around 3700rpm and found 0.6bar around 4300rpm.
Will keep updating as I enjoy it more and get some dyno time under its belt.
Well I jsut got home from spending the morning on the dyno, Cars still at the dyno :P
Car has a slight oil leak which I will need to get fixed up during the week, but it developed a problem about 2 hrs into the tune where it would idle but not rev.
Pretty much as soon as u touch the throttle it cuts out and just stops.... weird thing is if u start it and push the pedal straight away and get it over 3500 it will run fine while not at idle :S tuner said he has seen similar with a dodgy CAS, Can anyone shed some light on what could be causing this? or if they have had this problem before and came across the fix?
Car was making 143kw and 390nm limited to 7000rpm which is all we could push it due to the fact the airlines to the wastegate liquified causing the gate to hold steady at 4.5psi woooooooooo so the hightemp airlines arent so Hightemp so I will have to source a better solution before we can try again.
Cheers
Cameron
You are due for change in luck soon....but on the topic of high mount turbo setups, there is no such thing as overkill when it comes to using teflon braided lines for wasetgates, braided and sheated lines for oil returns and supply etc etc. Then planty of heat wrap etc...everything just gets so toasty under there
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
