murrayis Posted January 19, 2010 Author Share Posted January 19, 2010 (edited) Does anyone know where I can get -10 black braided line? doesn't have to be anything special it's just for the breather lines. I have found Pro Lite 350 Hose Has anyone had any dealings with this? Or know a good supplier as most prices I can find are around $60/Mtr Edited January 19, 2010 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5043750 Share on other sites More sharing options...
murrayis Posted February 21, 2010 Author Share Posted February 21, 2010 Ok a little bit of an update, Finished setting up the Haltech e11v2 and installed finally the Oil Catch Can setup. Tried to turn it over today on what Haltech said should get it started as a Base Map not expecting it to fire and it didn't few nice Backfires and I decided to leave it at that If anyone has a Map for a Haltech e11v2 for a rb25 with 750cc injectors I would be very grateful if I could get a copy to see if I can get the car running before I book the dyno and the tuner. Anyway here is a quick Pic of the engine bay as it stands now. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098229 Share on other sites More sharing options...
Wheezy Posted February 21, 2010 Share Posted February 21, 2010 KU Engineering plenum? Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098271 Share on other sites More sharing options...
murrayis Posted February 21, 2010 Author Share Posted February 21, 2010 (edited) Wheezy, You are correct with a BMI 80mm Throttle Body. Does anyone know what the firing angles for a rb20det are? I have them when I used a wasted spark setup but now I have the haltech I am not sure what the firing degress are. Cheers Cameron Edited February 21, 2010 by murrayis Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098278 Share on other sites More sharing options...
mico Posted February 21, 2010 Share Posted February 21, 2010 nice !! Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098398 Share on other sites More sharing options...
murrayis Posted February 21, 2010 Author Share Posted February 21, 2010 nice !! Cheers! Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098628 Share on other sites More sharing options...
zebra Posted February 21, 2010 Share Posted February 21, 2010 Wheezy,You are correct with a BMI 80mm Throttle Body. Does anyone know what the firing angles for a rb20det are? I have them when I used a wasted spark setup but now I have the haltech I am not sure what the firing degress are. Cheers Cameron 120deg for an inline 6 IIRC? Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098660 Share on other sites More sharing options...
murrayis Posted February 21, 2010 Author Share Posted February 21, 2010 120deg for an inline 6 IIRC? Thats what I was thinking, I'll double check this with Haltech tomorrow just want to make sure as it seems when cranking to be popping weird as if the timing was all wrong. Also need to get the type of CAS and if its on the Rising or Falling edge etc, I miss my Adaptronic where you could jsut tell it the engine and away it went lol Cheers Cameron Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5098896 Share on other sites More sharing options...
Wheezy Posted February 21, 2010 Share Posted February 21, 2010 How do you find the KU plenum for response against the factory intake manifold? How is your top end also. I ask because I have one and have not spoken to anyone else who uses one on a 20. I just wanted to compare thoughts. Obviously the 2.4L will be a bit different, but close enough I guess Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5099127 Share on other sites More sharing options...
murrayis Posted February 21, 2010 Author Share Posted February 21, 2010 Wheezy, Not having it fully tuned yet, results were pretty much as we expected its fairly responsive and flows plenty in the top end however I did port the manifold out to match the head and I also have 270 degree Cams. Cheers Cameron Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5099146 Share on other sites More sharing options...
bubba Posted February 22, 2010 Share Posted February 22, 2010 (edited) OMG so close! I can plug the laptop in and see what settings my Neo is running if you want.. Edited February 22, 2010 by bubba Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5099599 Share on other sites More sharing options...
murrayis Posted February 22, 2010 Author Share Posted February 22, 2010 OMG so close! I can plug the laptop in and see what settings my Neo is running if you want.. Bubba, If I could borrow your Map that would be great Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5099611 Share on other sites More sharing options...
Wheezy Posted February 22, 2010 Share Posted February 22, 2010 Wheezy,Not having it fully tuned yet, results were pretty much as we expected its fairly responsive and flows plenty in the top end however I did port the manifold out to match the head and I also have 270 degree Cams. Cheers Cameron Interesting resultes, similarly; with my stock engine, I found it responded the same as a factory manifold but up top over 7,000rpm it keeps making power whilst an other RB20 I have seen with the same turbo drops off. Cant wait to get some cams in it though. Good luck tuning it! Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5099683 Share on other sites More sharing options...
murrayis Posted February 22, 2010 Author Share Posted February 22, 2010 Good luck tuning it! Cheers, Tuner Is calling in tomorrow afternoon so hopefully we can get it started all goign to plan. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5100073 Share on other sites More sharing options...
murrayis Posted February 22, 2010 Author Share Posted February 22, 2010 Thanks for the lend of the Map Bubba i'll give it a try in the morning and see how I go. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5100511 Share on other sites More sharing options...
bubba Posted February 23, 2010 Share Posted February 23, 2010 So did it work?! Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5101411 Share on other sites More sharing options...
murrayis Posted February 23, 2010 Author Share Posted February 23, 2010 So did it work?! Have not had a chance to try it yet, Been fighting a XenServer all morning Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5101418 Share on other sites More sharing options...
bubba Posted February 23, 2010 Share Posted February 23, 2010 May the force be with you. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5101456 Share on other sites More sharing options...
murrayis Posted February 23, 2010 Author Share Posted February 23, 2010 I Hate Tuners.... I spent 20 minutes yesterday trying to get it started, He sat in it turned the key and it fired up instantly!!! And Yes the timing belt is a little too tight, Will have to back it off a tad. Thanks again bubba for the Map. Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5101787 Share on other sites More sharing options...
bubba Posted February 23, 2010 Share Posted February 23, 2010 Awesome! Link to comment https://www.sau.com.au/forums/topic/164666-project-24/page/14/#findComment-5101814 Share on other sites More sharing options...
