Thats odd, what pistons are they?
I will be doing first start up of my fresh SR in a couple of weeks and am concerned about getting something wrong.
I am under the impression that idling the thing too long before getting into the run in to cause this sort of issue. Was this the case for you?
thanks for the confirmation..so then i just need to change to forged aftermarket connecting rods as the rod shoulder looks lower than stock rods..earlier i think that stock rod gonna fit at first and after dummy fit,it wont..btw, nice project u got there.. :)
Edited by ian_adzrin
  • 4 months later...
  • 5 months later...
So I think my patience has finally ran out and I've broken the back of the bank account for the final time.....
So I've decided to get EOI to part out everything I can salvage from the engine.
If you or you know anyone who could be interested in any of the following let me know - I'm thinking i'll cut my losses and stick a bog stock 26 in an move on....
The List:
Rb20DET Tomei 272 9.25mm In+Ex Cams $600
RB20DET Tomei Solid Lifters $600
RB20DET Tomei Valve Springs $350
RB20/26 HKS In+Ex Cam Gears $250
Spitfire Coil Packs $200
RB20 HyperTune Custom front facing plenum * Work of Art*
Hypertune 90mm Throttle Body to Suite above
Prefer to sell as a pair $2000
SARD 650CC Injectors $400
RB26 SARD Fuel Rail $200
RB25 Top Mount T3 Manifold
Kinugawa To4z/Gt35R * I think Combo* Turbo
TiAL 38mm WasteGate
Custom 4" > 3" Front Pipe to Suite above combo
Kit $1300
Rb26 Crank Good Condition $800
Ross Balancer - Need to check if this is for a rb26 or rb20 $300
Eagle Rb26 Rods *Little end will need bushes replaced as they were re-sized to suite pistons - Roughly $4 each from ACL* $450
Nitto High Flow Oil Pump $800
ARP Rb20/25 Head Studs (Brand New In Box) $200
ACL Rb26 big end bearings +0.001 (Brand New In Box) $55
All Prices are neg. however I'd like to get the most back out of this 6 year ordeal. I Can provide pictures for serious buyers if requested. Condition on all items is excellent and most have only seen less than 5 hours of engine work.
Cheers.
What's hard about it? What specifically do you want done?
I cannot see a great difficulty in assembling one engine.. I would be prepared to do it.
Unless you want stuff CC'd and full micrometer blueprint job. I don't see the need if you were happy to sell all at loss and whack in a stock motor. You may as well assemble and use the thing.
yea i want to know the CR and measured and get recommendations on why the piston skirts have worn so much in such a short period and then recommend a piston.
the last two builds didnt last more than a few hours on the syno and these people knew what they were doing....
if i can get away with it id love to complete it and use ca18 pistons but i dont know if they will do the job.
The skirts would be worn due to bad piston to bore clearance, nothing else. It can't be anything else. It's probably a similar reason why there has been blow by issues (bad machine work).
When I built my motor and took it to be tuned I was given praise about how good it was. When I gloated that I built it myself I was given a rude wake-up call that the machine work was where the fine art is, and not so much the assembly.
That said, it sounds like you had machine work issues on both your failed builds and you should source your own machine work. Then you can sit down and assemble the thing slowly and gap your rings per how you would like them to be.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
