Well it appears I have accumulated a bit of money in my bank Account again, so before the Mrs finds out I figure its best to spend it on the GTR :bunny:
Looking to replace my Standard suspension next.
Car has 400rwHP, Runs Semi RComp Tyres, Brembo F50 brakes, and Button clutch but everything else is standard.
Car is a toy, is used only for Track days, cruizes and maybe the odd show, so dont need / want anything to flash.
I've pretty much narrowed my choices to whats shown below, which is budget adjustable ride height Coilovers.
They all seem fairly similar in price and features so which do you guys reckon is the pick of the bunch, any that should be avoided, or are they all much of a muchness and should I just buy the ones with the brand name I prefer?
Apexi N1 Evolution Damper Curcuit
Key Features
- Upper mounts for all models and adjustable upper mount where appropriate
- Largest diameter available, 52/46 diamemer and single tube type cylinder
- Upright type adjustable in 25 steps, inverted type adjustable in 13 steps
- Advanced new damper oil which controls oil deterioration developed from GT racing
- Quick adjustment for attenuation power adjustment
- Dust boots in all models
- New design height pitch wrench attachment
- Can be rebuilt
$2700 Delivered
Buddy Club - Club Racing Damper
- Height adjustablity w/ high quality aluminum perches
- 15 way adjustable dampening
- Pillowball upper mount and camber plate
- Buddy Club springs
$1905 Delivered
Cusco - Zero 2 Suspension
$1790 Delivered
Endless Zeal function Xs
Linear Spring Motion with no Friction Loss is superior and the shock can be adjusted precisely (Function-Xs includes 6-Way Damping Adjustability). Lightweight aluminum upper mounts, spring seat preload and spring seat lock, height-adjustable lower brackets and lock seats (for non-strut type applications) include a durable, Alumite finish for rust proof characteristics. Steel shell casing includes a special chromate plating for rust proof characteristics also.Adjustable brackets are newly designed and slender
$1908 Delivered
HKS - Hipermax II
The Hipermax II coilover suspension kits have been engineered to be track ready suspension that is still "streetable". Dampening and rebound can be adjusted simultaneously in 30 different increments to deliver the desired shock compression and rebound stiffness. Ride height is adjusted by simply rotating the 60mm spring retainer perches around the chromed steel shock body. The dual interlocking spring retainer perches prevent spring movement and unwanted ride height changes
$1813 Delivered
Tein - Mono Flex
- Full-length adjustment and height adjustment for separate setting of the height and spring preload.
- 16 levels of damping force adjustment (compression and rebound together).
- Teflon coating for rust prevention.
- Newly designed spring seat and spring seat lock for easy height adjusting.
- Pillow ball upper mounts are included.
- Compatible with EDFC.
$1945 Delivered
Trust Greddy - Type S
- Advanced Monotube design
- Screw type adjustment for increased accuracy
- Strengthened rubber upper mounts for improved rigidity
- Adjustable upper mounts where model permits
- Lightweight aluminium brackets to reduce weight over standard components
- Lightweight specially designed manufactured high tensile steel springs
- Produced by Takeshi Tsuchiya
$1621 Delivered
Tein - Superstreet
High performance and cost effective.
- Ride height adjustable.
- New paint coating for rust prevention.
- Pillow ball mounts are optional (on certain applications).
$1421 Delivered
Cheers
Lindsay
Edited by PSI_GTSII
https://www.sau.com.au/forums/topic/164677-which-coilovers-would-you-choose/
  • Replies 69
It all depends what you want to do with the car.But for all round you cant go past the tein stuff.
$1421 is a bloody good price for the super street.I havent seen them that cheap.
Care to PM me on where you get them for that price.
Stay away from the G4 and HSD.Those adjustments arnt entirely acurate,and its more like 7-10 points of adjustment rather than 36.
Also the spring rates are all over the place.
benm: Thx mate i've seen the whiteline groupbuy, for right or wrong its not really what i'm after
nytsky: just nengun mate ;)
Edited by PSI_GTSII
I quite like the HKS Hypermaxx II. Thye best car i have ever driven at teh track had them and Nismo adjustable arms. The car was brilliant to drive. Much better then my car.
On the street though it was a bit harsh...but on the track i quite liked it. And combined with that it seemed very quick and grippy as well
nytsky: just nengun mate :P
Why?
Is it infinite height adjustment you want?
I can arrange Eibach coils and Bilstein coil over conversion kits (add $900 to the Group Buy kit price)
If you want NON rattly spherical bearing tops I can arrange Noltec ones.
Or is a brand name thing?
:nyaanyaa: cheers :domokun:
your really after suspension,why wouldn't you look at top quality german engineered suspension with springs bushes designed for aussie conditions & at the right price, up to you mate of course, but i'm not the only one who is more than happy with sk's group buy....whatever way you go good luck & good driving
Why?
:P cheers :banana:
Speaking for myself, infinite height and a brand name is a major thing for me.. Out of interest, what does your group buy have on the likes of custom order Buddy clubs, or the likes?
Why?
:banana: cheers :banana:
I knew I would have to explain myself regarding this decision :banana:
Basically all it boils down to is I want a change, I know for a fact SK's Whiteline group buy will be a well sorted package, better infact than a set of Jap Coilovers.....because.....I have ran Whiteline springs, Swaybars, strutbraces etc with Koni Shocks in my last two Performance cars (SR20DET Bluebird & RB30ET R31 SVD GTSII Skyline).
Coming from a background of Engine swaps into Predominantly Aussie sold Jap cars I was always envious of the Jap import boys seemingly endless availabilty of Bolt in over the counter stuff, now I am one of those people I want to do the same :P
Personally, I think jap coilovers are fantastic, but only on the track and japanese roads. All the roads there are silky smooth. Even the suburbs. No potholes, nothing..Just nice smooth and flat roads.
No they are not. They are no better than Australian roads.
I can vouch for the SK Bilstein + Whiteline kit. Have it installed in mine and really improved handling over my std struts + king springs.
Ive heard the HKS are possibly the hardest setup you can get and (common) Superstreet's being the cheapest. I like the look of the upside down Monoflex though..
lol, I was thinking the same thing. Having spent a fair bit of time driving in japan now it's definately not all billard table smooth. yeah in tokyo the main roads are nice, and even out of the city in satelite citys like chiba the roads are awesome, but spread out a bit, or get on the back roads and it's a different story, plenty of potholes etc, but they do seem to be quick to fix them around tokyo.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
