Hi everyone, I'm fitting a GTR bonnet to my R34 GT-X skyline, i have a pair of conversion hinges and top mole (nose) on order.
Can anyone tell me what needs to be done to the cars lock mechanism so that i can retain the catch on my new bonnet?
If you have done this your help will be greatly appreciated.
Thanks.
Well you could try buying the GTR latch from nissan. About $80 brand new.
Not sure if it would solve your problem , you might also need to the upright part the latch bolts onto as well.
Is that all it would cost, i assumed it would cost an arm and a leg, had been trying to find a GTR that was wrecking.
Thanks, will call them tomorrow.
Thanks.
You will need both GTR latch and latch support if you are using a genuine GTR bonnet.
what front bar you going to use?
I'm using the factory fitted front bar (as shown in first post) but you can also use the Nissan Aero front bar as you can buy a front mole for that bar aswell.
The ultimate front bar for this setup is the East Bear GTR version as it fits non GTR's without changing front gaurds. (shown below).
I was bidding on the same bonnet you bought, but with frieght to Brissy it became too much
Yeah, could'nt believe my luck when i won the auction, i was'nt actually looking for a GTR bonnet but as a new one would have cost three times that amount
retail it was a bargain especially as it was brand new and had never been fitted and pickup was only 20 mins away.
wow, i should have really looked into the price before i got mine modified...
where did you say divide by 3 before? i can't find it... and i have no idea what the average market price for a bonnet is...
Average price for a R34 GTR carbon bonnet approx $900-1200
This new one sold for less than $470 on ebay. Was old stock and shop wanted to get rid of it.
It was going to cost me approx $150 freight plus the chance of it getting damaged, so I did not bid too high on it
Plus I already have a genuine alloy 34GTR bonnet on my Stagea
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
