Okay guys.
So I know exactly what a surge tank is, I also know how to set one up.
My question however is WHY install a surge tank?
I mean I always planned to install one as I thought it was just one of those things you are supposed to do, especially if you have a high HP application.
However I have been doing some more research and talking to a number of people with high hp cars and they dont use a surge tank. Hell they look at me crazy for even talking about one.
Essentially the setup is very similar, just without the tank. They use a lift pump to get fuel out of the tank, then have the line running to a larger pump (or 2 pumps) then route it the way you normally would. They completely eliminate the surge tank.
So my question is, if it is not used because that is the only way to supply enough fuel to the system in high hp applications, what is the primary purpose to install a surge tank?
Thanks guys.
-Sayajin
  • Replies 40
so the fuel system doesn't get air in it due to the sloshing fuel in the tank, given the high rates of tank scavenge in big hp applications (and the sorts of driving such cars are used for)
Means there is a constant air free supply of fuel to the pressure pump. When dragging or circuit racing as your tank gets low and the fuel is being thrown around the pump can suck in air.....well thats my understanding of it....
Okay guys.
Thanks guys.
-Sayajin
Thank you very much for your question, which is more than wonderful ;) I wish more useful answers!!
oil surge....fuel surge. Both shit things especially in racing. Im surprised you know what one is and how to fit one up but yet not know the purpose behind it.
lol, I'm surprised too. especially since it's name pretty much sums up what it does. anyone (i assume) can see that you want your fuel pump sucking in 100% fuel in a straight line, under braking, around a corner etc ALL THE TIME. with a big arse fuel tank fuel will be moving away from the pick-up under all those conditions hence the need for a surge tank.
You don't need a surge tank if you are going to race (circuit or drag) with no less than 1/2 tank of fuel ALL the time.
The idea of a surge tank (say 3 litres) is so you don't have to carry around an extra 35 litres of fuel all the time.
At an SG of 0.75, that's a weight saving of 26 kgs.
:nyaanyaa: cheers :domokun:
bkc, you're cool dude, but can you please reduce the size of your font to the same as everyone elses and with no bold... My pupils get 5mm wider everytime i read your posts :nyaanyaa:.
thanks.
thanks.
When reading his posts I sit further away from the screen.
:domokun: cheers :P
Yeh or your stupid enough to put a 40 litre fuel cell in the boot which surges no soon as your fuel level drops below 30 litres....*points at self*
This is an interesting topic to me.
Going back you would never even consider trying to run up a gtr with 550rwhp on a single in-tank fuel pump.
Now it gets done all the time.
People used to spend $1000's on over complicated fuel systems that made your boot smell like a BP refinery.
I am wondering now what in-tank options can take you to 700rwhp.
A single intank bosch 044 seems good to about 550 - 600rwhp.
Does anyone know if you can fit Two bosch 044's through that nissan fuel tank hole ?
Is their a pump that can be mounted in-tank that flows more then an 044 ?
Edited by Butters
In tank, 2 x 044 mounted one above the other, the top one simply has a longer pick up hose to the strainer. Been done before.
:P cheers :banana:
You could put as many fuel pumps in your tank as you want but all it is reliable for is on the dyno or sitting still....
Start drag, circuit etc etc and see how well it works....and you cant say 'ill keep the tank full' cos it aint gonna happen with 700rwhp and a couple of laps.
Yeah fuel hose 'breathes' but if you run braided stuff it minimises the smell - to a point.
It's all braided. I realise that fuel hoses 'breathe', but the in cabin smell is unbearable even after 15 or 30 mins of parking car with windows closed, engine off. Open the door and you could almost pass out from the vapours. Luckily I don't smoke :P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
