can anyone recommend a good mechanic?
Guest Malleus
Hi all,
My r33 gts-t started misfiring under load after i got it converted from auto to manual. Can anyone recommend a place to get it fixed?
I took it to Hybrid in Artarmon, but they reckoned it needed a full rebuild ( Dr evil voice: "Riiiiiiiight"). The miss started right after the conversion, so i doubt it's because the bottom-end bearing has suddenly died.
so who can people suggest?
https://www.sau.com.au/forums/topic/1647-can-anyone-recommend-a-good-mechanic/
Malleus, ring mark up at hills motorsport
he works on a couple of the cars in this club, and knows skylines VERY well, and is priced alot better than bd4's or CAS which are also both very good also... tell him ure from the skylines Australia forum's
his number is
Mark - 8802 0777
Guest Malleus
Thanks guys,
Yeah, Hills seems to come recommended in another mechanic related thread too.
I've had work done through Hills (that's where i got the conversion done, so i know them pretty well)
My only problem with Mark is that he's a bit too enthusiastic about taking on work, and so he's usually overbooked. If they can get another mechanic or two in I reckon they'd be great.
The conversion took about 5 weeks, and there was/is still some stuff unfinished...they knew what they were doing but were just in too much of a rush to do the job well.
also, Hills is waaaay out there, with no public transport nearby.
Still, I might go back there since they know my car, i just need to get them when they aren't busy.
Guest Malleus
All up about $3700
was about $2500 for parts and $1200 for labour. I got a heavy-duty clutch ($500) so I could have done it for less, but Mark at Hills found a buyer for my old auto tranny so i got $500 back for that. (the auto box had been tricked up a bit, was snappier than a normal auto, hence was worthwhile selling)
The labour was a bargain, Mark put a lot more than $1200 worth of work into it, but then it also took him 5 weeks. Initially he said it would take 1 week. Most of the 5 weeks was spent looking for parts.
How's the manual now?
Bloody great, cause it's a manual. Second is a bit rough, (i think the synchro is on the way out) but then i did get a used gearbox so you take your chances. Only problem is this frikkin missfire, so i can't fang the car/go to track days etc :)
still, I'm happy i got the manual.
My baby got towed over to Hills today, so far can only speak the highest of them. Only minus is the call backs (not happening) but guess they don't have enough time as it is, so its all good :cool:
Mark gives a good impression of knowing his **** which makes me feel confident about leaving it with them.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
