Hi all
I've just ordered a new 2007 model HKS SSQV for my R33 GTST, just wodering if anyone knows anything about them, or have any ideas on how to fit them, is it the same as the old SSQV, any one used it on ur skyline yet?? any reviews?? any comments r welcome! I know i should've done more research before i buy it but just got excited when i saw it and bought it straight away ;)
Here is a pic!
https://www.sau.com.au/forums/topic/164702-2007-new-model-hks-ssqv/
Looks pretty much the same as the old HKS SSQV, i've had a new one bought brand new in 2003.
Mine bolted straight onto the original stock bov mount, you'll have to block off your stock bov return pipe.
Unless your running a decent amount of boost it doens't sound the best.
have fun :nyaanyaa:
Can I just clarify something... We GTS25t owners cannot get anything to solve our idle problems if we choose to disconnect the stock recirculating valve and use a vent-to-atmo BOV?
Is it possible to still have the stock one connected, to control idle properly when you decelerate and come to a stop so you dont stall and still have the vent-to-atmo one as a primary?
Hi all
I've just ordered a new 2007 model HKS SSQV for my R33 GTST, just wodering if anyone knows anything about them, or have any ideas on how to fit them, is it the same as the old SSQV, any one used it on ur skyline yet?? any reviews?? any comments r welcome! I know i should've done more research before i buy it but just got excited when i saw it and bought it straight away :P
Here is a pic!
how much mate?
One of my mate told me to get an Apexi AFC (Air Flow Converter), tune it and it will solve the problem, but that costs around $450 which is not cheap! but i will take it to the garage and see what they can do about it, also see how bad the idle problem is! I will let you all know
Yes, this must be stock ECU related, I am going to buy an Emanage Ultimate sooner or later so I might run the Stockie for now...
Just seems a bitch that they run off these recirculation systems, the older nissans didnt run anything like this. they didnt run anything at all lol.
Yeah a friend of mine has fmic, aftermarket Blow off valve, bit more boost and has a SAFC car runs sweet!!!!
Have you actually tried running an atmospheric venting BOV in place of the stock one? When i bought my car it had a turbosmart atmo BOV on the stock ecu, with the recirculating pipe blocked off with a welsh plug, and it ran without a problem at idle, accelerating, redlining, whatever. Later i bought a stock BOV for it, and there was no difference again, except the sound (i think atmo bovs are a wank anyway).
Make sure the return pipe is sealed up tight and it will work fine.
Hehe for $310 i think ur gonna get owned :)
Yeah i know its abit cheap, but seems like a very good seller with over 10000 ratings but yeah i'm taking my chances, someone's gotta get owned to find out if its the real deal! i will get back to ya when i get it! fingers crossed!!
if its that easy!! then i will do wat you've done n save me the bucks!! sweeeeet
I was running T/S Vee port stock ECU, FMIC, 10 psi, zorst and no stalling or idle issues. ?
just a bit of pop pop out the zorst on gear changes!
Agreed, TurboSmart Veeport or Type II as they are also called, is the best and probably only atmo BOV I will ever use. In 6 years of using one, I have never had a drama with stalling or rough idle.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
