1991 Model, Prices range from $7500 to $10K for a STOCK STANDARD example in the NSW Tradingpost.
Only 120,000km
Blue, standard exterior, wheels interior.
7MGTE MA70 Toyota Supra Motor
Brand new Auto gearbox
EMS Stinger recently tuned at Roccos
Full exhaust
Big T04E and Manifold
45mm External gate ported to exhaust
Front mount Intercooler
BOV
Bleed Valve
Pod Filter
Alarm/Immobiliser
Standard features:
Leather Interior
CD Player
Climate Control Air-con
Power Windows
Power Mirrors
Central Locking
I don't doubt the car is worth itself in parts.
If you wanted to you could sell the turbo/manifold/wastegate, BOV/bleed, and the EMS, engine and car seperately - if you choose to buy it. Can negotiate the addition of the standard 7MGE engine and if you wanted to return the car to stock and sell it that way. There are many options.
Please email me for further questions [email protected] or call me on 0403 312 068.
I am pricing the car at $8K for serious enquiries only.
Photos are located at http://www.penrithweb.com/cressida/
Rick
The car is currently running 8.5psi and was dyno'd at 200rwhp (150rwkw)
On 12psi it pulled about 230rwhp (170rwkw)
This was on old plugs and a couple of dodgy leads, so I don't doubt it makes more. Through an auto power figures are not as high as manual . The stock Supra Intercooler is now the biggest restriction.
It goes suprisingly well for the power figures :P
  • 3 weeks later...
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
