Im selling my 180sx is a track car
I need something I can drive strait away as I dont have the cash 2 rego this car atm and ide rather someone use it than it sit in my garage.
Mods:
RB20DET (from a cefiro)
RB20DET gearbox
Sunroof
FMIC with custom piping
GTR Fuel Pump
Exedy heavy duty clutch
Aluminum Radiator w/ 10" thermo
Full 3" Straight through turbo back exhaust
Apexi Stainless Intake pipe
2 way mechanical diff
Adjustable castor rods
Origin Lab 20mm Front and 50mm Rear guards
Full BN Body kit (Type 2)
Vented Headlight cover
5 stud conversion (S14 Front and rear brakes)
Esta Zelda Tri-spoke 17x8 and 17x9 rims
Speco Boost and Water temp gauges
Jaycar Independent Electronic Boost Controller
Full stripped interior soon to be re furnished
Cobra Reclinable Race seat
Drift handbrake button
Tomei Gear knob
Gates Racing Timing Belt
JJR Deep Dish steering wheel
Standard Suspension
Custom painted rocker covers + all cooler piping sprayed black
Most vacuum lines replaced with silicone hosing
Custom oil catch can (made out of a spray can )
Pretty much every panel re sprayed in Satin Black inc front n rear bars (old paint was a bit rough)
Brand New Adjustable rear camber arms
Brand New battery
Brake fluid flush with new fluid
Swapped Power Steer pump (old one was noisy) with a Cefiro NON-Hicas Pump with new fluid
Removed Radiator and cleaned and put new coolant in
Here are some pics:
I am open to ANY offers people PM me and I will let you know thankx
https://www.sau.com.au/forums/topic/164759-drift-built-180/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
