I've got 2 R33s, one's a '94 GTS-T and the other's a '95 Type M- the syncro seems a bit slow on both of them, and is possible to beat on both up and downshifts, no crunching but felt resistance. Are they all like this or is this a sign of age/wear? One's 72,000 the others 92,000 kms so they're not ancient.
https://www.sau.com.au/forums/topic/164762-slow-syncro/
you are right in saying that they feel slow. My car has very low ks on it, and it's like this. same as my friends who has a brand new just jap box in it ($3200). It's just the way they are.
Yeah. 4th and 5th Synchro's are pathetic. 1st, 2nd & 3rd are okay, I've heard people get good results from a gutful of Redline lightweight shockproof. I've been quoted V.good prices to do a bearings & Synchros rebuld by 2 different places, food for thought.
https://www.sau.com.au/forums/topic/164762-slow-syncro/#findComment-3055700
I actually find 1-4 the same. 5th is the one that i find really slow - I put the gear stick there and wait for it to pop in. Feels like it's taking forever.
Having said that though, 1-4 feel pretty gay in the sense that they're a bit notchy. I know that that's the way that the box is, because my friend's r33 has a brand new box, and it's like this too (running vmx80 mineral oil - good stuff - i've used the synthetics except redline - wont' touch that crap, and imo vmx is the best for your box).
https://www.sau.com.au/forums/topic/164762-slow-syncro/#findComment-3059368
Out of the 33s I've driven, none have really performed how you said.
Mine slips straight into 5th not a drama, the only gear that is notchy occasionaly is second gear, and it has the syncros dieing on it.
https://www.sau.com.au/forums/topic/164762-slow-syncro/#findComment-3065782
  • 1 month later...
What sort of cost is involved in replacing synchros? I need to re-do mine.
My diff is also leaking, any idea on $$?
Cheers
https://www.sau.com.au/forums/topic/164762-slow-syncro/#findComment-3170491
Synchro assemblies are about $130-150 each.
I've just had my box out and found the synchros were not worn out. The cone/ring assemblies were glazed and required bead blasting to de-glaze.
Reassembled and using VMX80 it is like a new box. Very precise and just notchy enough to let you know exactly where things are. Very large single synchro on 1st, then doubles on 2, 3. If there is any apparent weak link, it will be the quality of change from 4th-5th, going on the synchro design there.
FWIW, the internals look like they were designed to take lots more grunt than a stock RB25. There is even a factory-included internal trap door to prevent oil surging to the rear of the box under hard acceleration. Keeps the main gearset well lubricated. :whistling:
https://www.sau.com.au/forums/topic/164762-slow-syncro/#findComment-3183962
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
