  • Replies 68
yeah, not needed for this, but as ports says it's a good idea anyway as there are no marshalls at these days which means if your car catches on fire all you'll be able to do is stand there and watch it burn.
i reccomend the BFI 1kg one. if puts out 4 times as much "stuff" as the other 1 kilo ones I've seen and owned.
so johnny, are you going to take off your slippers and come out? If I can drag my battle scared GTR out, surely you can wheel out the love boat for a play?
I was talking to Jason this morning and he reckons you are a bit scared of his GTR, but you should come out anyway just so he can show you the lines etc.
That is gold the slippers and the cardigan. GTR Jason is on the phone giving me a rev as we speak. You guys are sort of going about it the wrong way though. Try angle that Zeds are boats and drivers can't drive and they just look good.
i was going to try the all show no go line, but for that to work your car would have to be good looking...
but I guess at least if you come out I wont be the slowest guy on the track.
like I always say, if you can't be the part, look the part. and I certainly look the part...
I am 90% sure that I will be there tomorrow.
For those going, come and say Hi, even though I don’t drive a Skyline. It will be my first time on this track, so would be keen to pick up some tips and suggested lines.
I just pushed all my meetings and have taken Anual Leave see you all there.
Forecast for Wednesday
Partly cloudy. Chance afternoon shower. Northeast winds. Local early fogs.
City: Min: 15 Max: 23
West: Min: 11 Max: 24
Perfect temp, with a possible drift arvo if it rains
Dam - sounds like a good day - wish I could make it :laugh:
So tempting but simply too hard and can not go. Got way too much on with getting new shop ready and dyno room for this Sat SAU dyno day. Would love to come out and chop GTR Jason again, well at least give it a good go. Also preping car for Circuit Battle next week at Wakey. Sounds like a great bunch of candidates going and perfect weather and conditions too. Ports and maybe Wizard my Zed buddies I think are going and give these Skyline boys a run.
Got the day off so i think i will put on the r-comps and head up there.
need to see if iv'e fixed the oil leak from Phillip island.
see you there.
wiz
yeah top day. paul was down to 1.22 or there abouts and I was a second or two off that. I used the video camera for my times, will have to check it out later.
yeah it was nice to rub shoulders with glen seton and he even signed my seat. happy days.
Top day it was good to streatch the legs of the GTR, and do it without loss of licence. Big day with respect to numbers, it was the fullest I have ever seen OP, still good value for $120!
See you all next time.
Apollo,
I will post up the insurance name once my friend gets back to me.
Thanks
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
