Hi there, Just want some opinions on a noise that my R33 Gtst makes when its idling. Its a hard noise to describe but it sounds a bit like "woooooooo" noise or a hollow sounding noise. Im thinking it maybe the belts making the noise as I had them changed not long ago but im not sure and wonder if anyone else has this same noise. It only makes this noise when its idling, when your driving the noise goes away its only if you come to a stop at the lights etc that it makes this noise again. Any help would be appreciated.
Thanks
https://www.sau.com.au/forums/topic/164788-weird-noise-on-idle/
Is the car in neutral with the clutch out when making the noise?
If so, its the spigot bearing and is nothing to worry about until it gets really bad and starts clunking. It sits just behind the flywheel so the cost to fix is the same as the labour required to change the clutch
