Panel Air Filters
At a guess being carb all the dash loom will be different & will probably need more work there or replaced.
By robbo_rb180 · Posted
yes easily doable was very common conversion around 15+ years ago Require: Sr20 cross member and engine mounts sr20 gearbox or bell housing if manual CA already sr20 loom and ecu sr20 radiator (or make a cross over pipe to us CA style radiator) sr20 engine All parts can be sourced from an s13 Will require some mods to engine loom to body loom plugs but plenty of info out there on that. -
Also check the factory 2 wire coolant sensor is functioning properly and plugged in. Ignore the dash, the dash uses a different temp sensor.
Yes, it will fit, with the right engine mounts, plus a complete wiring loom. The CA is carby fed, yes? Then you need to add a complete EFI pump system (probably a whole tank) to get that to go. I don't know the 4 cyl stuff that well, but I'd be reasonably sure you'd need an SR gearbox, which will definitely need a clutch, and probably lead to needing tailshaft mods (although maybe you'll get lucky there). There will be more. Not from me. Just on the list.
