Hey there guys. Over the last few months I’ve had scores of people asking me to do a tutorial on how to install speakers correctly into the doors of the R33 Skyline. Well we (obviously) had to wait for another R33 to come in for the treatment and that has happened this week with an R33 GTR. So without further ado, this is the procedure for doing the doors correctly.
Step one: Take one original door complete with factory moulded plastic base speaker. Take plastic off and remove residue.
Step two: Apply sound deadening to outer skin.
Step three: Add diffuser panels behind the speaker. Tie the factory speaker wires (hanging down in image) to the loom as you'll be running aftermarket ones.
Step four: Run aftermarket speaker cables through modified door plug socket. In the Skyline where the cables run through to the doors, we simply machine a single hole (diameter varies depending on gauge of cable; pictured below is Audison Connection Sonus 14 gauge). This hole should be located between the main wires and that is where the aftermarket cables run through. These holes are traditionally blank. If need be you can also remove the plug totally and run your own loom tubes.
Step five: Sound deaden inner skin and remove air bubbles. Seal spacer onto door. Leave enough clearance for door handle and lock control rods to move freely. Also leave a little deadening around the top of the speaker hole to act as a 'roof' against water when it rains.
Step six: Create the spacers. These should be drilled to match up with the doors factory holes ensuring you don't damage the car by drilling holes).
Step seven: Make sure the midrange has a gasket because there is little use in going to all this trouble and then having no seal on the door itself. Solder the trimmed speaker wires onto speaker. Don't use crimp terminals because their two best traits are falling off and creating resistance.
Step eight: Heat shrink around the terminals to protect them. Unlike electrical tape, heat shrink will not begin moving after a couple of months.
Step nine: Screw speaker onto spacer. Make sure you seal around the baffle and place a gasket between the speaker and the baffle in order to keep the bass strong.
There you have it; one Skyline door done, Fhrx Studios style. :3some:
Edited by Fhrx
  • Like 2
if you want to get the best out of your audio hardware you need sound deadening.
if you are a DIY person then for approximately $150-200 you will hear a massive difference.
the same additional spend on more expensive components will rarely make an audible difference.
Just as a side note; I added these additional images to the other thread in CAA so I thought I'd add them here too. They show the passenger side door plug from the back end and our standard R33 battery / earthing kit upgrade (including the custom alloy brackets to avoid damaging the car).
Edited by Fhrx
Marty where do the negative runs all work their way to?
Like Wolverine said, sound deadening is a great investment, and will make even mediocre speakers sound decent. If you're worried about the extra weight slowing you down (like I was), Marty's reply was to 'eat less kebabs' :sorcerer:
You can deaden just 'half' the door, still to good effect. Pics below are more of Marty's handiwork, on my old car. Note that the stock speaker mounts were retained, but a diffuser pad and new speaker wiring was still used.
  • 4 weeks later...
The negatives all run to the cars body. Two connections to each shock tower and the last one goes down the the diff tunnel bolt. It just makes the car body a much better earth all around. :)
As for the deadening on the outer skin, you simply feed it in through the holes. :laugh:
Do you have any pics of how u made a "roof" above the speaker to stop it getting wet? Because i want to get a bit just to make a "roof" but i cant quite see or work out how to do it?? Much appreciated.
Check out the 5th pic.
Instead of cutting the hole for the speaker all the way around, leave about an inch on the top section.
This is folded back in the door and will act as a "roof" for the speaker.
  • 3 weeks later...
sweet, i'm getting some alpine 6.5"s today - hope they fit as nicely!
edit: they fitted perfectly - stock mounts, stock screws. until i can be bothered getting a really good system and doing it all properly, this sounds sweet anyway :D
Edited by made_guy
  • 1 month later...
Nice Just a question if anyone can answer:
"Step three: Add diffuser panels behind the speaker"
What do they do? :D
Read here: http://www.dynamat.com/products_car_audio_dynaxorb.html
Basically they absorb sound waves reflected off behind the speaker into the door cavity.
  • 3 weeks later...
Just a question on modifying the door plugs >> Is there a trick to getting these in and out easily? The area under the dash where the plug socket is located is incredibly cramped... I don't think even an ant could turn around in there. Short of taking the door off to get proper access to this plug, is there something that will make the job easier?
Thanks in advance.
  • 3 weeks later...
Yesterday I started an install of some new splits in my R33, I'm also interested to know if there are any tips to get access to the door plugs/sockets from the reverse side (passenger side, above ECU).
I hit major issues with running new cable through the factory plugs, I managed to remove them and drill the holes, however I had problems with getting the socket to stay in place (theres no room to move) - unfortunately the 2 metal clips that hold the socket in place fell out and into the body of the car. Any ideas where I could get some new clips?
On the drivers side, similar thing happened but I managed to hold the socket in place as I tightened up the bolt and got the plug to hold in place.
What would I need to remove in the (passenger) footwell to get access to the back of the socket to hold it in place and feed the wire through?
Also I initially tried to run 2 pairs of wires through (tweeter and woofer) and have the crossovers inside the car (and the tweeter mounted at the top of the door trim on both sides).
Any ideas how I could fix this prob?
Cheers,
chicane
Edited by chicane
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
