Official Sauwa Cruise - Perths Most Haunted Places- Oooooooo
  • Replies 412
Posted Images
I'm lookin forwards to it, will be there in my newly acquired maroon r33.
It will be interesting to see how scary the haunted places are when 300 cars with sikm8 sik exhausts and neons turn up, but anyway =P
Hey Brad,
If you still dun mind cruisin past Madely to collect my nav, im all for it. I wana fill up at woodvale and cruise down with the northern crew... so to get there for 9, plus collect my mate, id say we will have to leave the brook around 8:35.53pm... wot say we meet at the main shop car park near macca's??? *maccas meetup... sounds so 90's!* :blink:
p.s. what batteries do i need to get for the uhf?
p.s.s. Lauren and Paul you going to join us? it was your idea Niz!!!
Im pretty stuffed from work and spending 4+ hours in a car is a little excessive for me at the moment (you get to 24 and your staying power diminishes!)
So i think i will be going straight there - probably finishing up about half way through - if paul wants to kick on - i'll send him off with one of you boys :D
The weather seems to be clearing, that's a good sign :laughing-smiley-014:
looks like i spoke too soon :blink:
all that time washing my car, now it looks the same as this morning
not happy jan.....
The SOR was intentionally meant for another club I'm a part of (imports101), but I leaked the info hehe
Rock up anyway,there will be people from here there as well but I can vouch for them all as being good people :blink:
Yeah its the one there just off the Freeway, its called Murdoch Park n Ride I believe.
HI HI.. Do u guys reckon the Weather will b OK like later on tonite...?, i'm still thinking if whether i should go depending on the Weather... or Whether Weather hahha
-SeSaR
Edited by Black_CSR
im thinkin it should be ok... but im not to sure... i work near freo hardor and the cloads coming along where clearing up.. but yeh im not too sure... just come anyway...
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
