Official Sauwa Cruise - Perths Most Haunted Places- Oooooooo
none of you guys bothered to inform the other boys to follow onto the next stop which means we all drove home after freo prison.. quite dis appointing team work
i didn't just buy 1 map.. i baught a 2nd one also
enuf said... 2maps and still didn't make it past freo :) there was no set times to arrive/depart meetpoints... people arrive/depart whenever they want
next cruise ill shout you a map and bring a snatch strap so i can't leave without you :(
mate... chill... its a cruise and its all for a good cause... have a laugh about it rather than a whinge... forget my comments and think of the money raised... peace
  • Replies 412
Posted Images
well said xXx
i think who ever organized all that fog up in the hills needs a pat on the back, great effects ........HAHAHHAHHA
playa_32 get your car bak on the road bro hahahah and good timing on puttng your roof bak on the supra!
amount of people does necessarily equal amount of cars, Dan told me 350 maps were printed ?
I sold off a pile with my girlfriend, as the last 2 went there were still a load more guys wanting a copy but Im sure enough people got a map so all the cars could join in or follow :)
congrats dan and the rest of the commitee on a great cruise. i was so blown away on how many cars there was. first skyline cruise and have only ever been on a silvia cruise and that was at city west and bearly half filled the outside car park. is good to hear that some good dollars where made for the starlight foundation. and only got pulled over once and that was for doing nothing other then driving luckily notihng came of it
cant wait for next time. will see u all there
Does anyone know who owned the pearl white stagea with QLD plates?
if so can they send me a PM.. looks almost identical to the car we are going to get, and just wanted to know a few more things about it.
thanks to Dan for organising the cruise! Look forward to hearing the estimate of how many cars were there and a final amount of $$ we raised.
Massive numbers - great cruise... Was a bit hectic but it always will with that amount of cars.
We got some awesome cars here!!!
GTRZILR - im jealous, id kill for that dude... So devo i aint got $80K to blow lol.
Well done to all who organised the cruise. I was tryin to find some raffle tickets and by the time i found the dude sellin em at freo meet point, i had left my money in my ute in the bottom carpark... Ohwell - nextime.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
