  • Replies 45
LOLOLOL
thast hilarious
see, its funny how an 18x8 +30 rim would stick out to far, however an 18x9 +0 doesnt?
i think theres more to the story, like an idiot behind the wheel
but on a side not, that would be some easy harness relocation there, the fender is almost all the way off!
what kind of fitment are you wanting? sunken or flush with the body?
to be conservatiev in the rear go 8 +15-+20
for the front since you can actually usea lower offset id go +0t to +10
however, if you do go with the offsets above please run a 215/40 or 45 tire so you dont rub the inner lip ont eh fender please
however if you want to go a little wider (9s are plenty)
if you go 9 x+25 or +30 all around on stock body (no rolling or pulling) SHOULD fit without poking at all. but i always roll my fenders so i cant tell you for sure since i rolled them as soon as i could
preferrably flush with body, legally I dont think you can go over 8" wide here as stock are 7"
I was hoping to get the same offset all round, so if need be I could rotate them, but this may not be possible along with having the nice flush look.
well the problem is the huns on the front are further in than the rear
If you wanted to go flush all the way aroundk you COULD, but youd need to slightly roll the rear fenders so you can clear the tires
but honestly, if the skyline/cefiro/S chassis guys can do it, what is stopping you guys?
you really think they are going to stop you and say , hey your wheels are too wide.....just say it came with 8s from teh facotry or something
They go off whats on your tyre placard, and it says factory is 7" widest, but yes most people dont give a rats.
But for example, how do you think 18x8's with a +35 offset would look all round?
according to the calculations
the rear wont be baddddd maybe a 10mm spacer
but you should get maybe a 20mm spacer for the front
its gonna be hugely sunken
thatswhy i hate stageas wheel fitment sometimes. its backwards compared to everything else. lower offsets front higher in the rear is weird
If Beastien is worried about using 9 inch rims to stay legal, the last thing he wants is spacers!
Try this calculator, you can work out from your current wheels width and offset to how the new wheels will sit
http://www.1010tires.com/WheelOffsetCalculator.asp
because its illegal to have spacers on your car here...i was priveliged enough to get them on my stagea and find out that you cant have them legally on your car and insurance wont touch you if they are on your car :ninja:
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
