  • Replies 45
LOLOLOL
thast hilarious
see, its funny how an 18x8 +30 rim would stick out to far, however an 18x9 +0 doesnt?
i think theres more to the story, like an idiot behind the wheel
but on a side not, that would be some easy harness relocation there, the fender is almost all the way off!
what kind of fitment are you wanting? sunken or flush with the body?
to be conservatiev in the rear go 8 +15-+20
for the front since you can actually usea lower offset id go +0t to +10
however, if you do go with the offsets above please run a 215/40 or 45 tire so you dont rub the inner lip ont eh fender please
however if you want to go a little wider (9s are plenty)
if you go 9 x+25 or +30 all around on stock body (no rolling or pulling) SHOULD fit without poking at all. but i always roll my fenders so i cant tell you for sure since i rolled them as soon as i could
preferrably flush with body, legally I dont think you can go over 8" wide here as stock are 7"
I was hoping to get the same offset all round, so if need be I could rotate them, but this may not be possible along with having the nice flush look.
well the problem is the huns on the front are further in than the rear
If you wanted to go flush all the way aroundk you COULD, but youd need to slightly roll the rear fenders so you can clear the tires
but honestly, if the skyline/cefiro/S chassis guys can do it, what is stopping you guys?
you really think they are going to stop you and say , hey your wheels are too wide.....just say it came with 8s from teh facotry or something
They go off whats on your tyre placard, and it says factory is 7" widest, but yes most people dont give a rats.
But for example, how do you think 18x8's with a +35 offset would look all round?
according to the calculations
the rear wont be baddddd maybe a 10mm spacer
but you should get maybe a 20mm spacer for the front
its gonna be hugely sunken
thatswhy i hate stageas wheel fitment sometimes. its backwards compared to everything else. lower offsets front higher in the rear is weird
If Beastien is worried about using 9 inch rims to stay legal, the last thing he wants is spacers!
Try this calculator, you can work out from your current wheels width and offset to how the new wheels will sit
http://www.1010tires.com/WheelOffsetCalculator.asp
because its illegal to have spacers on your car here...i was priveliged enough to get them on my stagea and find out that you cant have them legally on your car and insurance wont touch you if they are on your car :ninja:
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
